Need help.. please step in
Smokinhot
3-man rules!!!!
Lansing, IL
Ok, I'm still getting a ticking noise even after i changed the lifters. It definitely sounds like valvetrain but I need some opinions. I hope the vid is clear enough for some.
http://www.youtube.com/watch?v=uGGgA9pheBk
to describe it, it has a faint ticking at idle and gets loud when gassed. Its really noticeable on decel. The first night my brother and i had it out for tuning we did a quick burst we floated the valves at not even probably 55-5600.
could it be flat lobes on the cam? The old lifters had some scorching marks on the roller but nothing drastic from what i seen. And cylinder 1 and 2, the rockers didn't seem to come up as high as the others when i rotated the block
Thanks
Smokinhot
Smokinhot
3-man rules!!!!
Lansing, IL
I know :( Its just heart breaking spending all day yesterday in the rain swapping out lifters that probably ended up being fine just to have the same problem..
Smokinhot
Smokinhot
3-man rules!!!!
Lansing, IL
if it helps too
stock LQ4 cam, lifters, head gaskets, pushrods,and rockers. The only thing I changed was the heads. went from 317's to 799's (243 casting)
Smokinhot
Smokinhot
3-man rules!!!!
Lansing, IL
well I swapped the pushrods and rockers off the old 4.8 onto it and the noise is still there. If there is an exhaust leak I know it isn't causing the tick b/c I've had it buttoned up tight and it was still there. The next step is changing the cam, timing chain and oil pump..
any other suggestions would be great
http://www.youtube.com/watch?v=mLkw8hCVHYg
Runtz52
Manhattan
it sounds almost like my pacer does right now, did u get a new or used torque converter? are all the the verter to flexplate bolts tight? i just hope it doesnt end up like my lumina and u spin a rod bearing
Smokinhot
Smokinhot
3-man rules!!!!
Lansing, IL
hmmm, now were talking. No i haven't checked that, but i'm pretty sure it was pretty tight. But i'll check that tomorrow. It doesn't feel weird when driving, and it doesn't feel like its coming from underneath me.
Runtz52
Manhattan
i thought i had rod knock when i first heard it, when i got home i crawled underneath when running and it much louder around the bellhousing than it was by the oil pan, plus i can feel the vibration through the tranny case and nothing through the oil pan, ur tranny got an inspection cover?
Smokinhot
Smokinhot
3-man rules!!!!
Lansing, IL
yea, I had to hunt the right one done. i'll pull it tomorrow. I'm really hoping its something stupidly easy.
Runtz52
Manhattan
lucky bastard, my old junk requires removal of the whole trans, good luck to u man, hope it works out
Smokinhot
Smokinhot
3-man rules!!!!
Lansing, IL
well I may have the cover but i'm not out the woods yet. But i guess it is easier than having to pull everything anyway
KagA152
Columbus, IN
i feel your pain, my gtp has been ticking for over a year now and over 20k miles. i replaced the lifters and it went away, only to come back about a thousand miles later. im assuming some sort of oil volume problem, because pressure is good. i figured if it was bad enough it would have blown up by now, so i continue to beat the shit out it, and be embarrassed when i go to the drive thru
Eagle
Nemo me impune lacessit
Woodsticks, IL
Did you locktite the flexplate and tq converter bolts?
I'd almost want to hear it at idle (rather than reving it) and do the same walk around vid...
As much as I hate to say it, sounds kinda like a rod bearing. :ugh:
Eagle
Woodsticks, IL
How do you describe "floating valves" at 55-5600? What exactly happened?
Smokinhot
Smokinhot
3-man rules!!!!
Lansing, IL
ouch, i don't really wanna drive it like it is.. It annoys me as it sits
I bought new bolts from GM and they had their stuff on them, they were pretty tight going in. I really hope its not a rod bearing... I would really hate myself for not bring the motor to a shop before install for inspection.
I'll get that vid for ya.
its like the motor gurggles... bout the best i can describe it... The Fuel cut-off is at 6k and the shift point at 5800
02BlueGT
No Fucks Have Been Given
Now apearing in Hanover Park
Maybe it is the camera, but that sounds way too loud to be just a lifter, lifters are more of a metal tick, that sounds like a flex plate/exhaust leak sort of issue..... Even most rod bearings I've heard, once they get bad, it starts to sound like a hammer hitting the block
Eagle
Woodsticks, IL
I'm going to say slight chance of a failed lifter, or its a rod bearing. :dunno:
Next vid can be short. Let it idle, then hold about 1500 RPM for a few seconds and let it return to idle. Might help decide what's wrong.
Smokinhot
Smokinhot
3-man rules!!!!
Lansing, IL
the lifters have already been changed, the old ones didn't look all that well.
Ok so on a run down, what would a rebuild cost? I have to get this thing rolling already, I've been borrowing my dad's vehicle for way to long. :(
