Replaced Fuel Filter Yesterday... I coughed up $50 to have Tires Plus in Cherry Valley do it...
It seems to have fixed the intermittent stalling and running rough... It's like nothing was wrong except for the fact that when I am on I90, the SES light flashes... no misfiring... it's weird... I'm going to get with TheAutoGuy to use his garage to pull the plugs and regap them to .060 to see if it is that.
Flashing SES means constant misfire.... and if it was Cyl 1 and 4, don't those share a Coil?... also, for $250, you can replace the plugs, wires, MAf, and ICM. Why spend that at teh stealership?
Unless you have a ported blower and smaller pulley the N* wont net you much power gain but will give you a slightly quicker throttle response and will need a tune. Clean your MAF with a q-tip and rubbing alcohol.So it's a possibility that I am looking at a bad coilpack too, amirite?
Wires and plugs I should be good on, once I regap... wires checked out too...
If I am going to replace MAF, should I just pop off the money for a N* TB and the necessary related goodies?
Yeah, I read the original post, and didn't read the others...I see now you already tried that.
Even on a stock L67 I'd never run a .060 gap though. Maximum should be about .056-.058
