Need Help/Insight - 3800 stalling/running rough/acting like s00ls (weird)
RebelTJ
Coyote Bus Lines
Rockford
My car has been running rough every now and then ever since Wed night.
It was randomly stalling out at idle, stoplights, etc...
I replaced the spark plugs with ACDelco 41-101's on Saturday at TheAutoGuys's House.
While at work last night, it really didn't stall out as much as it did, but it did throw a SES light that went away.
I was attributing it to bad gas, but I am not so sure now because of what it did later last night when I tried to move it.
It acted like it was getting no fuel for about 5 minutes... I finally turned the key off and on about five times to let the fuel pump prime and then it started right up.
Therefore I am thinking Fuel Pump or fuel filter? are my assumptions along the right lines?
AlmightyBirdman
*shrug*
Detroit Rock City
My car did shit like that when my battery was dying. Get it tested, or check the connections to your battery. I would get it scanned to see if the code that you threw stored though, it could have something to do with it.
RebelTJ
Coyote Bus Lines
Rockford
I'd like to rule out battery... it has a really strong charge.
Concerning codes, I'll take it over to Vatozone... less than 2 blocks away...
wed was the last snow, so chances are you got salty water on the wires and they started leaking voltage and are now shot, though it could be other things...
next time it's dark out grab a bottle of soapy water and spray all the wires down...if you see a lightning show...replace the wires...if your a badass like me you can just ground one hand and run your other hands down the length of each wire...bettter than a cup o joe lol
RebelTJ
Coyote Bus Lines
Rockford
These wires still look the same as they did when I put them on in fall of '08...
There might be a dumb issue on my part. I may have gapped the new plugs too open... to 0.65. Autozone lists the 41-101s as needing gap of 0.60.
Either way, the car is throwing "P0300 - Multiple Misfires" and the exhaust smells like sulfur after it dies and I have to fight with it to get it back started. I may not have use of the heated garage where I changed the plugs, so pulling them out in freezing temperatures will have to do.
02BlueGT
No Fucks Have Been Given
Now apearing in Hanover Park
My car did this when my MAF failed, I had to two foot it to keep the engine running, try with the Maf unpluged (didn't work as a test for me, but others have had luck), or if you have someone nearby with another 3800, borrow the known good MAF and see if it fixes your issue.....
Oh, and check the FPR for a leaking diaphragm
PANDA
FRG
SHOULD HAVE DONE A VE TUNE MOTHERFUCKER
Eagle
Nemo me impune lacessit
Woodsticks, IL
+1 to wires, or possible MAF. Unplug the MAF and see if it changes. If not, damn near sure its the wires at that point.
the icm's are pretty bulletproof, though salt/water can get into the electircal connector unplug it and see if it's moist (7mm)
RebelTJ
Coyote Bus Lines
Rockford
I do still have an aftermarket warranty on this car, and it's looking to become a job where I will have the stealership work on it because I am pretty sure that MAF, ICM, and such are covered... I'll pay up to my deductible of $250...
RebelTJ
Coyote Bus Lines
Rockford
i just saw they are at .65? close em up, btw wires commonly break internally during twisting/bending of a plug change,
Started this issue before changing the plugs... I had some old Autolite 104's in it previously...
DD scanned it last fall at Luke's and it was sometimes misfiring on 1 and 4...
TommyGloves
CHICAGO
I have a low mileage 99+ MAF for sale if ya need it. I'll sell it to ya cheap. :)
RebelTJ
Coyote Bus Lines
Rockford
I'm thinking problem lies elsewhere now?
This issue doesn't crop up all the time, it's intermittent... could a Throttle Position Sensor that is going bad cause idle issues and Toyota Syndrome (constant acceleration with foot off of gas pedal)
The reason I ask is that today the car seemed even more possessed... idled up to 3000 RPM after I disconnected and reconnected the TPS... disconnecting and reconnecting the MAF did nothing... I did that prior to disconnecting the TPS.
RebelTJ
Coyote Bus Lines
Rockford
Replaced Fuel Filter Yesterday... I coughed up $50 to have Tires Plus in Cherry Valley do it...
It seems to have fixed the intermittent stalling and running rough... It's like nothing was wrong except for the fact that when I am on I90, the SES light flashes... no misfiring... it's weird... I'm going to get with TheAutoGuy to use his garage to pull the plugs and regap them to .060 to see if it is that.
