Need help guys!!
cobraj
We installed a BF 2.93 and idlers today along with NGK TR6's gapped at .025. Im getting dyno tuned on Tuesday and I just took the car for a short cruise (did NOT get into boost) and its bucking at a cruising idle and under deceleration. It can be felt as well as I can hear the exhaust burble when it happens. Any thoughts, Bobs out of town and I need to get this thing right by Tuesday morning. :dunno:
Flatliner
I'm kind of a big deal...
CAI/ MAF??? Do you have in same position?
cobraj
cobraj
Yeah I checked all that and disconnected the battery and its still doing it.
Flatliner
Is the air intake stock/ after market, which one, did you remove for any reason and put back on?
Do you have the stock tune in or a base tune in?
cobraj
cobraj
JLT RAI and its the stock tune.
Flatliner
Did you just put in on today, or was it already on there before the pulley change?
What you changed should have had no effect on your car if you are not on boost. My suggestion if you have time is put plugs back to normal gapping and see if that makes a difference for now.
cobraj
cobraj
The intake has been on there since last summer.
TCG Member 5219
cobraj said:
We installed a BF 2.93 and idlers today along with NGK TR6's gapped at .025 (thats what Bob wanted). Im getting dyno tuned on Tuesday and I just took the car for a short cruise (did NOT get into boost) and its bucking at a cruising idle and under deceleration. It can be felt as well as I can hear the exhaust burble when it happens. Any thoughts, Bobs out of town and I need to get this thing right by Tuesday morning. :dunno:
Gap should be .32-.38. Mine were gapped at .35 and ran smooth as glass. Tuned by DynotuneMP.com
noavgcobra
mine are also at .35 with a poted and pullied blower....give it a shot
cobraj
cobraj
Re-gapped to .032 and its running fine now. I woundnt have been able to drive it to rockford for the tune on tuesday the way it was running.
cobraj
cobraj
Will do, hoping for some good ones considering it put down 410 rwhp with just a cold air and exhaust on the stock tune.
