Need advice, engine problem
zimmer0924
Master Debater
Ok so today I went out to menards to pick up a few things in the cobra.
I did not get on it, drove like a grandma. When I come out the Cobra does not want to start. I eventually make my way under the car and see gas. I jack the Cobra up to find out that there is gas leaking out between the exhaust header and the head. Now it's only coming from the drivers side head and only one port. It's the one closest to the fire wall. Needless to say I just had it towed home and I'm F**kin Pissed. So if any body has any advice at all of what it could be that would be great. I think it may be some type of valve or head issue. Please help.
Flatliner
I'm kind of a big deal...
Do you have stock injetors? Could be that the injector is not seated right...
zimmer0924
zimmer0924
Master Debater
No there not stock, there 60lbs. I have had them on there for 2 months and everything is fine. The car was fine when i went into the store and not even 5 minutes later when i come out it wont start and gas is coming out between the head and the exhaust header.
Flatliner
Well I would guess it's leaking from one of those injectors. The fuel line comes up the passenger side right by the firewall and connects to the passenger side rail and then onto the driver side...
My suggestion would be for you to disconnect the battery, use a fuel disconnect tool and rag to soak up any remnants. Then pull the driver side fuel rail... I cant' remember but I think there is one or two nuts that hold it down. The injectors have orings, maybe one is bad or was pinched, or just not seated right and it just finally started to leak. Who installed them?
Flatliner
I don't know if you have seen them, these are not our cars,but gve you an idea why they might be leaking if oring is bad, pinched, or injector not seated right.
zimmer0924
zimmer0924
Master Debater
I'll check that out. I installed them by the way. It was not leaking out around the injector though. It was coming out the exhaust port. Would a bad oring cause that?
IZZy
Powered by ES
coming out of the exhaust port?
hard to imagine how it would sip out thru there, I think there is a leak on the line somewhere and it ended up dripping down there:dunno:
zimmer0924
zimmer0924
Master Debater
I'm really at a loss of words. It looked like the gas was coming out of the exhaust port. I'm going to take a closer look at it today when i wake up but damn. Just got this stupid car running a few weeks back. Shit
Dana
Bluesmobile
Pull the plug on the cylinder you suspect or better yet, all the plugs on that bank, then inspect each plug and cylinder for raw fuel. If an injector is stuck, it is theoretically possible for enough raw fuel to enter the cylinder that it could flow out the exhaust port when you crank the motor.
If this is in fact what happened, do not start the engine until the oil has been changed, once the repairs have been made.
Dana
Bluesmobile
Assuming you find an excessive amount of fuel in one cylinder:
A bad injector is not the only possible cause. The control wiring for the injector could have problems. If the wire is grounded, the injector would always be turned on, so before replacing the injector, check the looms and wiring.
There are other possible causes, but the fuel supply is the first place to inspect. The rest are not simple to diagnose or repair.
zimmer0924
zimmer0924
Master Debater
I will check for that today. Thanks guys.
Dana
Bluesmobile
I need to retire, really retire.
I have had the Cobra out once this summer so far and it still needs that Spring tweeking that's always necessary, not to mention a bath.
Don't even have time for food or beer, lost 15# so far.
That'll be good for another 10th though or at least offset the suspension mods I made last winter...
Dan
Dana
Bluesmobile
Ya, I didn't phrase that quite right, did I.
I meant it would offset the weight that was added by the suspension mods I made.
