Mysterious Water in the Passenger Footwell
EmersonHart13
Member Selfie
I know someone has had this and I have even read about it but I don't remember.... Where does the water in the passenger footwell come from?
Thanks,
John
Royalgtp
I have a little in my drivers side floor.......just a small little area that is always the same spot.....
Im thinking one of those plugs in the floor/frame of the car is off????
alexgtp
Thanks,
John
[snapback]98904[/snapback]​
There is a drain tube for the AC condensor and also where the water from the cowel drains to. If this gets plugged up the end result is water in the passenger footwell. Easuest way to get to it is jack the car up. and directly on the passenger side cowel you will see a rubber turb..gently pull it out and clear out any obstructions you find.
EmersonHart13
Member Selfie
Maybe the seal under the cowl? I have never heard of problems from the Driver's Side....
staceyyearsich
Crete
Oh that happened to me and it was like a damn flood take care of this first mine started as a trickle of water next a little puddle next a HUGE puddle.. just stick a thin metal/wire hanger up that there plug thing and clean it out and u will have no problems
