I
imported_Ron Vogel
Had to shelf my rail project until I source a good regulator (need to fab into rails), so I played with my exhaust again. My system consists of a mandrel bent 3" DP (with venturi cone insert) into 3" high flow cat, Magnaflow 30" body /36" length / 6" diameter / 3" id muffler, into 3" mandrel bent to 2/14" split to Ractive mufflers. It sounded deep and mean, but with the car lowered the big Magnaflow was scraping speedbumps, and I was never convinced that VE was maximized with it like this. So I got some flowmaster 3" to 21/2" reducers, and put one on each end of a Magnaflow 20" body / 4" diameter / 2 1/2" id muffler. After welding it in, I noticed a lot better throttle reponse, and overall it runs much stronger.
And, my intake tube was starting to get rusty since I never painted it, so I figured I'd clean it up. I wanted to try the faux anodized stuff anyway to check it out. I picked up the "metalcast" anodized finish system at Wal-Mart. Consists of a silver metallic base, and a red tinted clear (also comes in many other colors). After scuffing up the tube after removing the rust, hit it with some prep clean. Sprayed on 2 coats of the base, waited 1/2 hour. Then sprayed 1 coat of the tint, then baked it for 20 minutes at 275 F. Cooled it down for a half hour, then put on one more coat of tint and baked again. I have to say, am very impressed at the results for a spraycan system, and highly reccomend this stuff. Obviously, I have to see how it will weather, but my best hunch is that it will hold up well from how well it cured. I went ahead and did my fender braces, and will do a few more things with this stuff.
