my trans is on it way out
smug
Cedar Lake, IN
On my way to work friday I get a 3 to 1 downshift and on the 1-2 shift my trans is slipping and when it finally gets second gear, it hits hard. Turn off performance shift, same thing, loaded stock trans file to the pcm, same thing. I checked the fuild and it was full but when I wiped the dipstick on a paper town it left a black streak of clutch material. So I am considering my options of getting a morad trans, zzp, or maybe dynotech, or a local trans shop. I need some input here on what to get and from who. My car is high 12's, I drive it daily, larger rotors, 18" wheels, lowered, and i am not easy with the gas either. I know morad it the cheapest, but i plan on keeping the car or a long time and do not want another trans failure.
smug
Cedar Lake, IN
Originally posted by chipmonk212121@Oct 7 2006, 11:11 PM
just go out and buy a new car..... fixing one is too much work lol
[snapback]141857[/snapback]​
i wish i had your and chads money :lolsign: :lolsign:
PANDA
FRG
Let me rewrite that... :lolsign:
My car can run high 12's, I drive it daily and beat the shit out of it, I goto the track every few weeks....
REDHOTT04GTP
Romeoville
Originally posted by 2000gpgt+Oct 7 2006, 11:20 PM-->
<!--QuoteBegin-chipmonk212121
[snapback]141858[/snapback]​
[/b]
:lolsign: :lolsign:
chipmonk212121
[/b]
I wish i had the money i thought i had lol!
smug
Cedar Lake, IN
can anyone give me suggestions on what type of upgraded parts i should get on the rebuild
Royalgtp
Id get higher gearing and a higher tq convertor. I love how fast the car shifts with it.
I got and FULL intense trans about 2 years ago and 24k miles ago.....Performed great for the first 700 miles........then I found out Scott didnt replace the bands in a $4,000 dollar rebuild. :ph34r: :rolleyes:
SInce then its been great!!!!!!!!!
Oh wait, then there was the Gen 2 lsd revision......
Since then its worked great!!!!!!! B)
SaturdaysGS
Chicago (Southside)
[snapback]141900[/snapback]​
So you'd recommend a complete INTENSE transmission rebuild with the Gen 3 LSD?
:p
Sinister Drag Designs
SinisterDragDesigns.com
Chicago, IL
input shaft, hi stall 245mm torque converter, upgraded clutchs, stronger boost sleeve, diff squirter, upgraded chain(stock gearing,3.29s blow-my $.02)) i wouldnt bother with an output shaft.
dynotech or zzp, talk to them.......we buy trannys on this forum,not build em :D
TonzKnock-G
Shitcago
GET THE WORKS!! :headbang: On a side note I think my tranny is taking a dump too. Shifting funny as of lately. (stock pcm)
phat_ridegt
Ottawa
my trans is definantly on its way as well. if you plan on running 12's on a reliable DD i would def. go with hard parts, is/ps, basically go to zzp's website, and get every option, including free install :)
get everything bob said plus get some good axles while you are there so you can scratch them off your 'weak link' list
smug
Cedar Lake, IN
I talked to dynotech zzp and a local shop today and i will say that I was most impressed with the dynotech trans. It seem like basically i was going to get the most for my money from them and the guy i talked to anwsered every question i had for them. the guy i talked to at zzp, not zoom, basicaly told me to call certified, and certified told me to call zoom, so I felt like I was getting the run around.When i get $3,000 saved up I will be getting the 2500 stall converter, 300M input shaft, 15/16 drive chain with 3.29 gears along with the very long list of standard rebuild stuff they install, and a 12 month 12,000 mile warranty.
TonzKnock-G
Shitcago
[snapback]141987[/snapback]​
where is Dynotech?
smug
Cedar Lake, IN
Originally posted by tonzcompg04+Oct 10 2006, 09:57 AM-->
<!--QuoteBegin-2000gpgt
where is Dynotech?
[snapback]142083[/snapback]​
[/b]
New Jersey, the trans is getting shipped to my shop where I will install it
