My headlights look like crap
Freebeer187
The Bolt Rounder
Schaumburg
Ive got the clear corners which look real nice but the headlights look like shit. Grey and dull. How do I fix this? Ive tried wet sanding and buffing but it didnt work. I prollly did it wrong though.
Where can I get oem ones for cheap?
Eagle
Nemo me impune lacessit
Woodsticks, IL
ebay PROJECTORS, yes. Standard housings AFAIK, should be fine.
SHOmuff
Doing the damn thing.
Wheaton
If you're buying ebay headlights, or any aftermarket lights, its always a good idea to seal them up with silicone.
Freebeer187
Freebeer187
The Bolt Rounder
Schaumburg
These headlights bounce like no tmw. Ive tried fixing mine. One side is fine the other bounces like a fat kid in gym class
greasy
LTTR BOX
The Litter Box
The problem is not the exterior of the headlight. The inside of the headlight gets all mucked up.
greasy
LTTR BOX
The Litter Box
If the healdight comes apart it is possible, but you will have to reseal it to keep out moisture. Depending on how big the opening is for the bulb you can also use a small Mother's Polish ball and work the inside of the headlight like that.
greasy
LTTR BOX
The Litter Box
I forgot to ask, are the headlamps glass or plastic?? If it is plastic they might just have some heavy rock damage and will be unrepairable.
Euro
GM or Nothing
Roselle
Yeah, you could try to heat them up to get the headlight lens off, then try to work with them, but that doesn't always work. You could try the junkyard too for a cheaper way. Mine were doing the same thing, until I traded headlights with my dad's old 03 before it got traded in, haha
Eagle
Woodsticks, IL
Work that ball :pedobear:
Nice snag! :bowrofl:
PANDA
FRG
I bought a headlight capsule, bracket, and corner (as a package) for like $100 at the dealer. Buying the parts separate was like crazy money. I wouldn't fuck around with eBay junk, its nothing but junk.
Harbor Master
are you making sure you are inserting all the tabs correctly? there are 2 that slide in that must be perfectly aligned to make it not bounce... and they arent too noticeable if you dont get them in...
i thought it was the outside ? :dunno:
junky junk
in the trunk
Eagle
Woodsticks, IL
Mine dont bounce terribly, but they definitely bounce some. Pretty sure I got all the tabs in the correct place too...
...."in the trunk" :rofl:
ilikemtb999
I eat dirt
Denver, CO
eBay. Then just reseal them cause they all seem to leak.
Or take an extended test drive of a car with good lights :rofl:
Kbrown
Huntley, IL
my experience from ebay is fine...like everyone is sayin, seal them up with clear silicone... then there fine for sure.
lights in my sig are ebay lights....no problems since i sealed them.
shaferz
slaps a ho
Central IL
I would rather pay extra money for something that already works, instead of paying less money for something i would have to take apart and burn my time fixing. My time is worth more than that to myself.
Each to their own I guess.
Harbor Master
shaferz is straight ballin
