I really wanted to do the Rickey Gadsen trick they used to get the ZX9R into the nine's in the article, but the track (Rt. 66) wouldn't let me. Basically, you run a threaded rod through the front axle, and run barbell weights on each side. I put it on after I had the tech check it out, but was caught at the line with it...betcha at Byron it would have gone unnoticed!
About the foot peg thing, thinking about it...probably depends on first gear. I was set-up with 2 down in the front, and 4 up in the rear...plus first was steep anyway. First gear was good for like 15-30 feet at the track for me (or so it seemed).
How bout that. Didn't realize I owned a 9 second production bike, haha.
are you using the clutch when shifting? I know you are a big guy, but try tuckin in a little more if you can.
Does it have a strap? That will help keep the front end down.
