my Cooper S at the autobahn country club
Bru
Looks good :bigthumb: That's the North Loop, right?
I spent a day up there racing around that section of the track. Lots of fun and can't wait to do it again.
S
speedycoop
awesome!!
have a list of mods?
well you asked for it so here it is....keep in mind this is a 1.6L engine with only a small eaton m45 blower on it. depending on temp outside it runs between 19-21psi. whp is in the range of 250 with wtq at 217. car weighs roughly 2550.
Engine:
15% s/c pulley
4% crank pulley
stage 3 big valve head
shrick 264/272 cam
everything on intake side including the s/c runners(piping if you will) is all port and polished
62-60-64mm throttle body
msd coil and wires with ngk 1 step colder plugs
GRS intercooler
380cc injectors
UNIchip piggy-back ecu (car is tuned by GRD)
DDM intake
poly engine mounts
m7 oil catch can
exhaust:
miltek header
random technology 3" catback with electric cutout for straight pipe.
suspension:
hotchkis lower adj. rear control arms, rear 3-way adj. sway bar, front camber plates, and adj. sway bar end links at all corners.
alta springs
koni yellow adj. shocks
m7 strut bar
brakes:
wilwood front calibers and 12.5in 2-piece wilwood rotors in front
custom cut rotors in the back
hawk pads in the rear and an assortment of wilwood street-full race pads for the front.
stainless braided lines all around and MOTUL dot4 racing brake fluid (good up to 594°F)
interior:
schroth 4 point harnesses
ati gauge pod with oil press and water temp.
cravinspeed 3-way adj. short shifter.
track wheels:
16x7 SSR comps with kuhmo v710 R-compound slicks.
Fish
From the mean streets....
Chiraq
speedy, is it true that pulley swaps are around the 4 hour mark since you actually have to pull the blower?? I read that somewhere a couple years ago when I was looking at Minis.
S
speedycoop
yes and no. all you have to do is lift the whole engine up 2-3 inches. if you know what your doing it could easily take an hour or less
