My car has a new Whine to it, and not the good kind
Dasfinc
Mrrrrstang.
Wheaton, IL
For those that don't already know, I have a 2013 Mustang GT with a manual trans.
Car has a weep at the rear diff, and I've noticed a whine before putting it away for winter.
With spring, the whine is increasing in volume (and the pitch is related to road speed) and I'm HOPING its the rear diff, but the sound sure feels like its coming from the transmission (which is a little crunchy going into 2nd and 3rd when its 40 degree's or below).
Car has Blowfish shifter bracket on it (But STOCK shifter), is it worth the trouble to put the OEM stuff back on the car to bring it into the dealer? Or do you think I'll get flack for it. The other mods are under warranty (FRPP Tune and Axle-Backs).
I've had good experiences with minor mods at Rod Baker, but don't want to push my luck, and just wanted others thoughts.
El Presidente
[MENTION=2612]Pressure Ratio[/MENTION]
Harbor Master
so it doesn't have a supercharger then?
wombat
Wood Dale, IL
If it's got a warranty, why are you even asking? :dunno:
This sounds oddly similar to my Cobalt's whine (not from the sc) and they replaced my trans (twice, because they fucked up the first one) because of it. I do not recall what they said the problem was, sorry.
syP
Not Banned
Downers Grove, Illinois
just bring it to the dealer. rod baker replaced my trans even though I had a short throw in it. just be careful they dont get your car super dirty on the inside like they did mine.
1quick
coal city
The rear diff weep unless you can see it coming from the cover is most likely the vent on the driver side, there is a mod to stop that I just noticed mine is wet around that vent as well
Dasfinc
Mrrrrstang.
Wheaton, IL
I'm pretty sure its from the front input seal, I noticed it when we had it up for the shifter bracket install. I can't imagine a leak that 'high' up on the Diff would cause the noise I'm experiencing also, which makes me think the Trans is about to check out.
10sec
But you have a warranty...
Dasfinc
Mrrrrstang.
Wheaton, IL
I know this....
The question was just primarily seeking if I should remove the shifter bracket or not first. Also curious if I might get the "That's normal" push-back kind of thing, or "The bracket is causing extra NVH" (But I know that a high pitched whine is NOT from the bracket).
10sec
If you think they might make a big deal about it, take it off. :dunno: Seems pretty simple to me, DANIEL.
P40E
Seapage isn't going to cause a noise unless it's out of oil .
P40E
Put the top down . Miss Esa driving . Hop in the back seat and go for a ride and listen .
1quick
coal city
I have a friend that's a tech at rod baker I can get you his name if you want to request him look at it
1quick
coal city
That'd be appreciated if you could PM that over? Maybe even just let me know when he's in?
I don't talk to him a ton any more both of us with Familys now and what not but I'll shoot him a text later
Dasfinc
Mrrrrstang.
Wheaton, IL
Hell, I'd be happy even if he can just confirm that they don't have some crazy new Nazi-policy about mods when there are trans issues.
SleeperLS
Desert Racer
Sandia Mountain
I would take that bracket off if you think it is the trans. I could see Ford saying the extra ridgidity cause pre-mature failure.
