LOL.
I dont think you know how the cooling system works.
Id be happy to explain it to you if you dont figure it out first.
Fair enough, I am definitely still learning about the cooling system on these cars.
Lower outlet of radiator through thermostat to oil filter housing into the block feeding the water pump which pumps it around the cylinders in the block up through the head gaskets into the cylinder heads where it exits into the COT and the upper radiator hose.
Coolant is drawn through the heater core in the Mustang from the rear of the passenger head in the Mustang then into the heater core outlet tube which is fed into rear of the water pump in the block valley.
On the Marauder the heater core is fed directly from the COT.
The difference between what I am proposing and the standard cooling mod installation on a Mustang is a single cap installed on the Marauder COT.
So what have I got wrong?
IB TLR
