My 1995 GTS, (Good and Bad)
scca_stang
Owns Assault Rifles
so I got my car back (Bad trans).....
The Good: The trans feel good, it shifts good and I do not feel any wierd problems.... I got my Cobra cluster in my car and it works perfect, looks great too...
The Bad: the steel drive shaft feels unbalanced at 70-80 MPH, so I either need to get it rebalanced or buy another aluminum unit.... also my Steeda Triax shifter was completely roached, so I need to get another one of those also, I am using a stock one for now.... My power steering unit is acting up worse than before.... not sure if it is a rack problem or a pump problem, it seems to work fine at speeds of 30 or higher, but any slower and it takes considerable effort to turn the wheel, it doesn;t seem to return properly and it is a bit notchy (not sure of a better way to explain it)...
so I am concidering ditching the power steering for a manual rack from Flaming river.... they are $310 plus shipping... I guess my biggest question is, should I go with a standard ratio of 20:1 or a quick ratio of 15:1.... the standard ratio will be easier to turn, but the quick ratio will give faster response... have you driven a manual rack mustang? can you tell me if they are difficult to turn????
batman
Surrounded by 10 points
check ebay for manny rack, purchased one new for half that price(new)
no problems been on the car for three years
batman
parking lots is where you'll feel the manual, as long as the car is moving 2-3 mph your good
serb82
I would check and make sure ur tires are balanced before you go out and get a new drive shaft.
IZZy
Powered by ES
a lot more bad than good... lol
scca_stang
scca_stang
Owns Assault Rifles
good call, I plan to do that this week... especially since I had them mounted at discount tire, they have a lifetime balance.
scca_stang
scca_stang
Owns Assault Rifles
actually, the Good really does outweigh the bad... the body still looks good, the engine runs good, the interior looks great, the suspension works perfect and it's a Mustang, it can't be all that bad no matter what.
