Figured out I can't find my 1-1/8 socket for the pinion nut. Need to dig one up.
Also, did most of the brake line work and got my bracket done. I mounted the prop valve here as well as the line lock. If I ever do a V8 almost all of this will have to go. Probably hydroboost time.
I also need to do pads and hose on the other side. I suspect I will be doing the hard line there too with my luck.
Did some work on the head too trying to scout things out. First thing was I did a mic check on the valve mic. Seemed accurate enough based on my vintage AF Sears Micrometers. Wish I at least had em in tenths but w/e.
The mic wouldn't work with the spring locators the way they were. I had to cut these down anyways as the valve guides were way too tall and the keepers may have given me .5 lift worth of clearance on a good day.
The intake was about what I expected. Spec is 1.65, I'm thinking I probably needed to clean some crap off the seats from porting.
The exhaust on the other hand was a bit of a wtf. I'm wondering how much recession these seats have. I did 2 cylinders. Among my concerns is that the Jeep Valve train is 100% non adjustable so I'm at the mercy of the lifters to soak that lift up unless I get push rods.
Speaking of pushrods, I am wondering if the length on the intake is wrong. There's a lot more wear on the intake side than the exhaust, and it seems to be in the direction that the force of the rockers would act on the valves e.g. left to right if the head were in the engine. I think I'll at least buy a check pushrod at some point.
