I took it around the cul de sac yesteday. Probably the thirdish time. A few impressions so far;
-The steering is pretty damn good. Light and nimble
-The car doesn't seem top heavy. Going to have to play with it more. Overall the wagon would be more utilitarian but with gears and a stock 4.0L HO this would have been pretty darn fun in the day.
-The back is light in 2WD mode. Haven't put it into 4WD and that will be a bit, the vacuum lines for the tcase and axle disconnect need a lot of work.
-The engine seems to be pretty strong, you can tell it's lugging though and really needs more gear. 2.34s aren't great for performance. Bet she does okay on the highway.
-I haven't gotten it into second yet (not fast enough) but first and reverse are thankfully solid.
-The shifter sucks. Plain and simple. I have a B&M Starshifter I'm thinking of trying to integrate into the console.
-Bit loud, but not horrid. If I had the idle lower it'd be a lot better honestly.
-I want to get the tach lighting wired in to the gauge lighting which is a nice improvement.
-There's a tap from the passenger side that's rythmic as it goes. It may well be a wheel weight hitting the front control arm. It could also be the CV shaft pu there with a torn boot.
I spent about 15-20 minutes pulling the door card off to put the rod back on the handle. At that point I found out the lever for the pot metal is broken. Guess I'm going to be combing ebay for another one. If I were baller I'd get repops and look nice. Then again at those prices sketchy it is.
Here's what I'm working on. I need to get in there, tape some stuff up now (unlike the PO) and then shoot some black up top so it covers up the original paint.
Straight on. Not so bad is it?
You can see the contrast now. Lot worse when it's seen that way.
Much, much better. Not perfect but at least if I'm about to get t-boned at a light I'll know it now.
