gotta get to a pc to post details but I did the deed. Not perfect but way more solid than the Lemans.
It's a selectable hi-only AWD System. It's a NP style transfer case. I'm getting some Sy/Ty vibes here and that's kind of where I'm thinking I want to go with it. I believe the body is based on the Spirit.is it actually 4wd?
Curious about this, for the front? as I've got an 8.8 out of an Explorer that the cv rear brakes are going on.Long term I found out 12.4" cvpi rotors look like a go. That's way off
You should!!Excellent! Cool to see another one being brought back to life. Yes, a modified XJ tank will work. I've got a 4.0/AX15 swapped 82 Spirit with an XJ tank actually. Thinking about doing my own build post
I don't see what the thinking's for I actually have questions to ask when it goes up especially around the tank swap.Excellent! Cool to see another one being brought back to life. Yes, a modified XJ tank will work. I've got a 4.0/AX15 swapped 82 Spirit with an XJ tank actually. Thinking about doing my own build post
Alright haha twist my arm I'll start a build thread and dump pictures in it when I find the time after work.I don't see what the thinking's for I actually have questions to ask when it goes up especially around the tank swap.
Anyone know Dana 30s? I know I need low pinion gears but am finding out there were some "super 30s" used in Grand Cherokees. If I wanted to stuff those gears into my diff is that plausible? That's also besides the fact that I may have troubles with this being a 2.34 diff in the same way that Dana 60s are to Dana 61s.
Yeah based on what I found the '99 rotors are 12.4". Looks like minimum wheel size was 16s, so I'd have a maybe chance of them clearing? May end up swapping to CV wheels?
