🔧 BUILD Mook's 2016 Golf R | E85 and Typhoon powered
2016 Golf R, DSG
BOTTLEFED
2,699
5,477
I'll put this here
117,596
Reactions: BOTTLEFED
Ron Vogel
5,174
4,274
Ron Vogel
If you indeed have an injector issue, just put a screwdriver on the injectors and listen. I do that when diagnosing injectors. Also, watch the injector pressure. I had to dial back my HPFP multiplier to keep pressure below 3000. I was constantly popping injectors. If the seal to the head is bad it’ll also produce a loud tick
117,596
Both sets of injectors are (probably) fine. Gonna still try and get them flow tested though.........cylinders 2 & 3 have no compression annnnnnnnnnnd when scoped using a mirror, I have bent valves. So I'm waiting to hear back about a fully assembled ported and polished head. Fuck. My. Life.
Pistons are fine, so the bottom end is safe at least.
