Don’t send that negative voodoo my way. And I also am not running everything he was/is.Doesn’t your car uses the same engine powertrain. You’re probably next!![]()
If you’re getting oil on the plugs it would definitely make a difference in power.Would that cause the car to be down on power tho? Cause it absolutely is.
should be THE longest.owned this rig 5.5 years... is that like... top 3 longest vehicle ownership periods for you right?
i have led tails already.Did you ever look into that link I sent you about the LED tails and rear foglights?
Except that one pesky LED.i have led tails already.
oh. no, its definitely a burnt out led for the tails themselves.Did you ever look into that link I sent you about the LED tails and rear foglights?
yeah, but the "broken" LED's in yours might actually be Euro Rear Foglights.i have led tails already.
Do you have a machine shop do a balance and blueprint on something like this when they assemble or are these some sort of matched sets you can just pop in as long as the crank is in good shapeI've already got a block in the garage. Just gonna order up pistons and rods (and the small misc shit I'll need), swap those into the extra block and then toss that motor in. It'll all be done before spring. Thankfully I'm in no rush.
It'sDo you have a machine shop do a balance and blueprint on something like this when they assemble or are these some sort of matched sets you can just pop in as long as the crank is in good shape
should be drop in.Do you have a machine shop do a balance and blueprint on something like this when they assemble or are these some sort of matched sets you can just pop in as long as the crank is in good shape
