2016 Golf R, DSG
I'm triggering traction control often, which never used to happen. So not sure if thats good or bad.Its running fine. I MIGHT be down on boost simply b/c we stopped tuning because of a wastegate issue but the car feels healthy. I need to do an 1/8 hit to see where things are at.
Today's quick project, dynamic side turns. 15 minute job. $40 on Amazon.
What color you have in mind?I think I'm definitely changing the wheel color over winter.
I don't bother with them most of the time. They just get destroyed an hour later.wheels are dirty bruh
I don't know if you have EDC, but it's not a good thing if you break traction. On my car, it uses EDC for both axles. So it'll grab the brake on the opposite side of spinning, and hook-up. If it has to do that enough...it thinks the brakes are overheating and cuts power. I have 2 choices..(.I'm using this as an example if your set-up is same). 1. Get stickier/bigger tires 2. Remove ALL hints of traction control. Problem with #2 is 1 wheel peels on front and back...on opposite sides making car unstable. I can keep EDC, but I can not remove the nanny to prevent brake overheating...which is only a calculation as there is no temperature sensor. I know the best solution is #1 as fact...since my 275's hooked just fine and no nanny problems. When I went back to 225's it brought a lot of inconsistency to launches due to #2.I'm triggering traction control often, which never used to happen. So not sure if thats good or bad.
