Maximum Motorsports Steering Shaft - 94-04
1stmustang
NOT FOR SALE ANYMORE
Sorry guys, just found out today that I have to use this part in order to clear my headers. I apologize to the interested bidders
This is a brand new solid steering shaft from Maximum Motorsports, part #MMST-14. This is the much improved welded type. It is a typical MM peice in that it is solidly built and beautiful, pictures do not do it justice.
From Maximum Motorsports website:
Solid Steering Shaft Assembly, power steering, 1994-04 Mustang
You can sharpen your Mustang’s steering response with this solid steering shaft assembly. With your stock steering shaft, motion is lost due to the flexing of the rubber rag-joint. This flexing usually feels like play in the steering wheel (you can move the steering wheel without the car changing direction). The factory joints are replaced with race-quality needle-bearing U-joints, resulting in a dramatic improvement in steering response.
$225
bigtirecoupe
Steering shaft
Where are you located in New Lenox? PM me your number.
Thanks Denny
Fast99Snake
track rat
this is an awesome piece,
just make sure you throw some hi-temp spray paint on it before install, as it will rust very easily since it is completely uncoated from MM
