He was talking about the PRVV line.
Right - the vent for the check valve I think?
Absolutely fabulous work Zack! I think you set the standard in making both your work and thought process visible. You create a lot of confidence in the work you do
Thanks Mark.
Theoretically, I should be far far along with the project by next weekend.
Ive been trying to guess what power it will make. What compression in the shortblock you had done? Tha will determine the boost.
Compression is 9.5
I'm sure there are a number of thought processes on this but my understanding is the consistency of e85 is variable. I would need to check each fill up with a test strip - will the tune allow me multi settings to account for conditions?
Did you do our rear ES bushing mod Zack?
There's only 3 MM's running rear ES, make him the 4th
Whats the thread count on the heads Zack, and did you already have the cams installed?
