Machined intake manifold for IC...yes or no..
Royalgtp
I was wondering if I should get one of those machined intake manifolds for when I put the BTK intercooler on.....???????
I though I remebered a few of you guys not agreeing on this...
Mike K
Forum Sponsor
If the intercooler core is similar in size to the ZZP blower (which I beleive it is) then yes, you will benefit from a longer opening.
If you give me the dimensions, I will cut you one and you can just give me your old one back after install. :)
Royalgtp
[snapback]59540[/snapback]​
You have machining tools?
Mike K
Forum Sponsor
Originally posted by RoyalGTP+Nov 8 2004, 03:22 PM-->
<!--QuoteBegin-Mike K
[snapback]59548[/snapback]​
[/b]
I have cutting wheels, polishing stones, grinding discs and all that good stuff. To my knowledge, no one is CNC cutting these intakes, just cutting them out by hand and then polishing them clean. :)
CoolGTX
let sleeping dogs lie
Hotel 4 Dogs
ive got before tests done, just need to get my hacked up one on, for further tests... ;)
Royalgtp
[snapback]59581[/snapback]​
HUH?
CoolGTX
Hotel 4 Dogs
Originally posted by RoyalGTP+Nov 8 2004, 06:33 PM-->
<!--QuoteBegin-CoolGTX
HUH?
[snapback]59589[/snapback]​
:lolsign: :lolsign:
[/b]
im running my i/c on a STOCK intake manifold "presently"
I hacked one up at work, and will install it soon
tests are completed on the stocker, testing will begin when the modified one is installed
Royalgtp
HUH?
:lolsign: :lolsign:
[snapback]59609[/snapback]​
[/b]
Sounds good......Tell me the results.
xttc2000
youll get a TON more air in once you open it up. but you may lose some boost, which can be made up for with a pulley change.
