In that photo, it was that front middle piston with low compression. Don't have an air compressor otherwise I would try that trick. All rear cylinders had good compression at 150psi. But I wanna look at them anyway. If those look good... then I don't know. How did all 6 spark plugs get so fouled? Can the symptoms I described in prior posts be blamed on a gasket failure? Would it refuse to start if it was a gasket issue? Well, it did end up starting but was super, super rough, and RPMs were wheezing like a bad vacuum leak somewhere.
See now me, id still junk that motor and replace it with another low comp one. Its old tired and something happened and I just dont like gambling but thats me.
The motor is fine.
Since it failed the compression test, and ran like death, I think it was worth taking everything apart and getting a good look at it.
Once the engine is out, can't I take out the stock cam and check lobes real good? Can't I also peer inside the engine and take a look at the rods to check for damage? I will be able to see the rods once the oil pan is off.
With the engine out I can check everything thoroughly, and then put it back together. It's easy cuz I know the car and every bolt like the back of my hand. If anything, it's gonna make me feel more confident about the engine. The heads look good, the valley is shiny metal, the springs and rockers are shiny. There is very little carbon buildup as far as I can tell... in comparison to other pics I've seen anyway. This engine has a lot of life in it, I think. Doing this isn't really much of a chore. It's kinda fun and a rite of passage for any GP enthusiast. If the engine is somehow OK, then I can do some maintenance. I can get the valves lapped, new seals, re-gasket everything, clean it. Looking forward to it.
on the other hand when you go to start it you will be wondering if you forgot to lock tight one of the 500 bolts you touched or forgot to tighten, rolled a gasket etc. lol
turbo car has zero lock tite bolts
you put oil in the heads yet to see if they leak.
