YingYangY87thang
- Joined
- Nov 15, 2020
- Posts
- 418
- Reaction score
- 253
Ok so I did my diggin and all it brings up is performance stuff and no specs that I want but I'll bet someone here knows.
What's the difference in injectors in these lt engines? I see there's low flow I'm guessing for the 5.3, nominal flow and high flow I'm guessing for the lt4? Do these interchange? Should I have ordered the high flows instead of nominal for my 6.2 for e85? What are the rates and will I possibly need to tune for the nominal set I ordered? I wish I'd have looked closer instead of just pulling the trigger on what "fit" it's got the long crank issue and just a hint of stumble on idle and I'm gonna guess the tsb for the orings is the culprit and if I'm gonna go to the trouble I want as much injector in it as it'll take since I'm still tryin to decide if its just cold or if its white smoke comin out the pipe and I'm in for heads and might as well do a cam and dod delete while I'm at it if that's the case. Also what all will I need if it's just injectors? Intake gaskets and maybe the rail feed lines?
Also is that lip on the throttle body what everyone is porting out? Is there any gains across cam timing stuff? I'm still gettin a handle on this different ecm but a lil up top in the driver demand and a little timing down low seems to be where its at to add good torque across the board?
17 ltz 6.2 with 100k on it. cold air is on still need to do exhaust, flex fuel sensor, laser iridiums and taylor 409s. Alot of questions I know but I can't think of any better place to ask
