🔧 Technical LS Lifters
Ti28
Cupcake
Posts
11,575
Bartlett
Agree, I know in my head that’s the right move. It’s a process for me, lol. I’m selling myself and convincing myself of everything. Again appreciate all the input here.
That's the worse part about a LS, you just can't change the lifters by removing the intake. Changing the lifters is more-less a pain in the ass! You'd kill yourself if you'd pull the heads, not change the lifters, then 4k miles down the road a lifter eats itself!
Bob Kazamakis
I’m the f-ing lizard king
Posts
87,918
Probably more likely to spin a new “ls7” lifter vs what’s in there in 4k miles…..
JFish75
Addict
Posts
719
Winfield, Il.
That’s my dilemma, lol. Or if I change them and they fail or cause issues then I’m pissed I should have left it alone. Would need to think about new length pushrods also if changing.
Ti28
Cupcake
Posts
11,575
Bartlett
Boost Leeroy
When in doubt, throttle out
Posts
13,235
Cary
Yea know just a quick $600…. Then if you do change lifters…. Even to stock LS7 you definitely have to at least measure for pushrods. And if you do pushrods should probably go with a little thicker ones….. seeeeeee where I’m going with this. If your shit if working now just leave it alone. Make sure they all stay where they were and let it rip imo.
JFish75
Addict
Posts
719
Winfield, Il.
Depends on what you have now. I'd go a nice set of link-bars.
Yeah I hear that! Already upgraded to hardened push rods with the cam.
v6buicks
Posts
6,843
Franklin, IN
I think the deal with LS7 lifters is people getting knock off's. If you get OEM from GM I think they are still fine. Otherwise Johnson seems to be the way to go for 99% of applications.
This is what I've kinda gathered as well. The ZZP "LS7" lifters I bought were pretty obvious knock offs and you don't need to disassemble them to see that they won't last more than a few crank rotations in a stock LS or 3800. I think it's the people buying knock off shit because they believe everything they read and not inspecting anything who are trying to damn the genuine parts.
Broke EF
Posts
2,376
The sticks
But But according to the internet you just need 7.4 pushrods, no need to measure!!! I dont know why my lifters are failing!
Broke EF
Posts
2,376
The sticks
I dont remember the lengths off the top of my head, but I always measure as well. When I put together a motor it was somewhere shorter. I then had the block and heads decked/surfaced and I came up with 7.4! I checked like 80 times because it made no sense LOL. The point is, always measure :D
CMNTMXR57
Posts
28,602
Not knowing all you did, it sounds like you have stock block deck, stock head design/deck, stock rockers and you maintain the OEM base circle of the cam lobes regardless of change in lift/duration/lobe separation, you shouldn't need anything more than 7.4 in an LS motor. An LS7 lifter, OEM or knock off, shouldn't be that far off to change this, no?
JFish75
Addict
Posts
719
Winfield, Il.
Yeah I didn’t touch the heads other than replace springs and installed the brass bushings in the rocker arms and the aforementioned pushrods. Which makes me think it shouldn’t change, but not sure if the LS7 are the exact same height and preload or “close enough”. Decisions decisions. All the different info here is much appreciated but exactly what has been spinning around in my head. I just need to pony up and settle on something.
Posts
33,713
JFish75 JFish75 Brass? You mean bronze trunnions?
What's the actual verdict on best lifespan for a stock or barely bigger than stock bumpstick?
Bushing or bearing rocker pivot kits.
I'm getting the idea a good kit would be worth it to get genuine gm ls7 lifters.
And new trays. Didn't know that was a thing but I think I saw em included in the TX speed kit.
JFish75
Addict
Posts
719
Winfield, Il.
Yeah sorry, and yeah I agree seems like maybe the consensus is to get genuine LS7 lifters and trays. And yeah I would be getting the heads and probably just everything else from Texas Speed, make it a 1 stop shop unless I can get them for way cheaper and guaranteed that they are legit.
Posts
33,713
Well someone mentioned Johnson so I went on a tangent of some research and some say the tie bar kit is worth it. I believe the "race" units are the axle pressure oiled, descriptions seem to imply that's the main reason they are "race"
I spend too much time learning shit on here.
This guy I know John, cool guy, has a sweet banana with a purple trunk. There's even a drinking game involved somehow, dunno heard it from a guy kj.
:drums:
He's forced me to learn how far the Lsux aftermarket has come to keep eyes out for two ls4s if I ever find em.
We'd totally make 16 cylinders happen, hopefully with less than 58k in each.
Just working on my old junk I've lost touch with where things ended up since I haven't seen a FSC rag in a while.
Ti28
Cupcake
Posts
11,575
Bartlett
Vengeance racing and scoggin-dickeyare also good places. The god father of the LS works at scoggin-dickey
JFish75
Addict
Posts
719
Winfield, Il.
Yeah I am familiar with Scoggin Dickey, they’ve been around for a long while. I bought my plugs and wires from them a while back. I’ll check them out and compare.
