lq4 in a 98 trans am
ls1ta98
palatine il
Hey ppl how hard is to put an 2003 gmc 2500 lq4 317 heads on a 98 trans am
lastls1
It bolts right up. All the parts and mounting areas are interchangeable
lastls1
Wait are you talking engine swap or just swapping heads? Either way the heads will bolt right up as well. The 317 heads I believe will change your compresion ratio though
willizm
Ho fuckin Ho!
Saint John, IN
If swapping heads it will drop to approximately 9.5:1. If swapping the motor it is identical.
willizm
Ho fuckin Ho!
Saint John, IN
Swapping the motor what about harnes and computer from the lq4 motor
You should be able to use your existing ls1 harness and PCM. I haven't done the swap myself, but that is my understanding. Anyone else have insight?
Lead Pipe
I'm Tiny Riiiiiiiiick
LQ4's in Trans Am's is race car shit. It will swap right in and bolt up no problem. You have to run your T/A intake, oil pan and accessories. Harness and computer is all the same.
A couple things is you have to drill and tap an extra hole in the block to mount the PS pump or alternator, I forget which. Also If it is a 99 or 00 LQ4 with the iron heads the crank is 1/4' longer and won't mate to your trans.
ls1ta98
palatine il
I dont have the harnes and computer from the ls1 car just the one from the lq4 motor
Lead Pipe
You will need an f body harness. If it's a 98 T/A I would look for a 99+ PCM and harness. They can be found on tech pretty cheap. Unless you want to cut up the LQ harness and run it as a stand alone. The f body harness will have all the provisions for the TCM and BCM.
I just noticed you said 2003 LQ4 so you're good on everything lining up and plugging in.
lastls1
So am gona need a new trans?
Just like all the engine components the transmission will bolt right up to the rear as well. Assuming 4L60 or what not
Edit: If you are talking like a truck 4L80 then you need a different driveshaft compared to the stock Fbody one. Shorter I believe. But Will would know more on that
Lead Pipe
No, do you have a 4L60 or T56? Either will work.
What I'm saying is a harness from a 2003 truck will not just snap into an Fbody with out modification. The easier way is buying a 99+ fbody harness and PCM.
Smokinhot
3-man rules!!!!
Lansing, IL
Everything that [MENTION=3061]Lead Pipe[/MENTION] has said is spot on.
On a side note, better get that 4l60e built. It will not last behind a 6.0.
Mr_Roboto
Joliet
Is it an auto or a manual? Is the car original or was it tweaked? If it's original it's a 60E otherwise it could be damn near anything from a 'glide to a 6L90E
