Isn't .450v the default the ecm will readout if the o2 is unplugged? I'd be checking wiring like Turbo400 suggested, sounds like you have a break somewhere
Frank throw some of those o2 Fowler’s in that #2 spot. The trick is to double stack them. Make that fucker LLLLLIIIIIIIEEEEEE to the pcmEnded up having two separate breaks in the o2 heater wire. One rub through on the trans dipstick. Another no idea, just ran a new wire.
Thanks Nate for getting it squared away! He had it figured out and done in a matter of hours.
It threw a PO420 and P2272 now, I’ll throw downstreams at it but I’m not confident. It smells pretty much like the cat is toast.
Ya know I've never really had to deal with a restriction as much as I love my sawzall but I'm curious how a plugged cat show in a scan would it make things back up or rich or lean or my thoughts in theory would be no air moving and the pcm thinkin it's rich and pulling it lean as hell? And this is probably a stupid question but I've never ran across itNate Clogged cat won’t affect mileage negatively? Thing legit still smells like as if the cats were cut off lol
This is exactly how I feel about this terrain that keeps comin back to the shop. Took it across town got rocked 500 for an oil pressure sensor and diagnostic now trannys actin up and on torque showin one sides probably got a pcv leak and the other fine but two weeks ago both trims were lean on hp. I keep tryin to get the girl to get rid of it before I end up havin to put a timing chain or transmission in the bastardAll right now what you're going to need for the gas pedal is a brick. Then you're also going to need a really high cliff
Trust me you’d know if you had a restriction. All I’m saying is pull that rear 02 out of the stream enough to where the pcm thinks the converter is operating correctlyNate Clogged cat won’t affect mileage negatively? Thing legit still smells like as if the cats were cut off lol
name of the game is as cheap as you can right?
