Looking for some technical help.
2008 Sierra 1500 with a 4.3. 323,000 miles.
Truck was experiencing poor fuel economy and had a CEL. Codes:
-PO050- Ho2S heater control circuit B2 S1
-PO059- Ho2S heater resistance B2 S1
-PO154- o2 circuit no activity detected B2 S1
-PO155- o2 sensor heater circuit B2 S1
Looking at live data bank 2 upstream was hovering right around .450 for the most part, no LTFT corrections, etc. Sweet, easy peasy throw a new pair of upstreams at it.
Just replaces both using Denso sensors (part # 234-4337) and cleared the codes, light came back on immediately. Truck still has the PO050 and 155 code. Checked fuse 8 and 18 for o2 sensors, both are fine. Now, after about a minute after startup the truck misfires and throws a flashing CEL. No misfire codes, but misfire history on cyl 2,4 and 6 and I can watch the misfire count on live data. After 3-4 min of misfiring at idle it clears up and runs great. Zero misfire count to speak of. To the best of my knowledge from messing with this for the past hour or so once it stops it will not start again until you shut the truck off and restart.
Any ideas? As far as the o2 heater goes, I’m going to assume it’s a bad ground or messed up wire going to the sensor, but the newly found misfire issue has me confused.
Thanks in advance!
Thanks in advance!
