🔧 BUILD LikeABauce302's 427 SBF Twin Turbo Build. 404 Error: LS Content Not Found
Since I've been on this site for awhile now, I figured its time to post up the project I've been working on. Some of you may recognize the car. The previous owner raced it quite a bit and ran it in the IMSM series.
Here is my 90 Mustang LX hatchback:
Mod list:
Engine:
-Stock block bored .040" over
-Stock crank
-Forged rods
-Forged pistons
-Balanced, machined, and assembled by Opel Engineering
-Edelbrock Performer RPM Heads
-Edelbrock Performer RPM II Intake
-Basically your typical stock block H/C/I SBF
Transmission:
-Freddy Brown Built AOD
-Manual valve body
-Transbrake
-3200 RPM stall converter
Front Suspension:
-AJE K-member and A-Arms
-94/95 Mustang spindles
-Moroso Trick springs
-Lakewood 90/10 shocks
-UPR Castor/Camber plates
Rear Suspension:
-TRZ double adjustable upper control arms
-TRZ single adjustable lower control arms
-stock springs
-Lakewood 70/30 shocks
Chassis and Rearend:
-Welded full length subframe connectors
-Welded torque boxes
-Aluminum driveshaft and safety loop
-Custom 9" rear end
-Roll cage soon to be installed
Brakes:
-Maximum Motorsports manual conversion kit
-94 Cobra master cylinder
-Wilwood adjustable proportioning valve
-Maximum Motorsports braided lines
-99 to 04 GT brakes all around
Wheels and Tires:
-Chrome Pony R Wheels
-Rear: 17x10 with 275/40/17 M/T ET Street Radials
-Front: 17x5.5 (narrowed by Weldcraft) with M&H Racemaster Radial Front Runners
There are probably a few things I'm missing. I bought the car in December of 2009 and it's been a work in progress ever since. It was a solid well built car when I bought it, but it needed some work to make it street driveable.
How the engine bay looked when I first started working on it:
Teardown and preparation for cleaning up the engine bay:
Beginning to fill in all of the holes in the engine bay:
Engine bay all finished:
5 lug swap time:
94 spindles all cleaned up and new hubs installed:
Maximum Motorsports manual brake conversion with 94 Cobra master cylinder, and new UPR castor/camber plates:
Finishing installing new brakes up front:
Test fitting the new wheels
I've still got some work to go. Before spring I'm going to freshen up the rear end and I'm planning on installing a Holley EFI system. If I have enough time and funds left over, I want to install a roll cage of some sort since I'm planning on running at the drag strip quite a bit.
Reactions: HeavyG and Rico
LikeABauce302
5,930
16,526
South suburbs
Matt
Some progress made today. I put in 50 hours of work in 4 days this week, so decided to take today off and work on the car this morning.
I finished adding supports to the driver's side wastegate, got the passenger side turbo back in place, welded in the passenger side O2 bung, and installed the passenger side downpipe.
Gussets added top and bottom to the driver's side wastegate pipe.
Passenger side turbo back in place
Passenger side O2 bung welded in
LikeABauce302
5,930
16,526
South suburbs
Matt
LikeABauce302 LikeABauce302 you using a folding welding table? How do you like it
Yeah I'm using this one below. It works fine. For longer sections of exhaust or heaver parts it can be a little tricky to position things. Having an extra vice to set on the table is helpful for those situations.
Steel Welding Table, 1.1″ (28mm) Tabletop Slots, Adjustable Angle & Height, Casters, Retractable Guide Rails, Eccentric Leveling Foot, TS3020 https://a.co/d/hCOji5T
Jimy Bilmo
CSVT OG Member
TCG Goldmember
61,425
v6buicks v6buicks
Reactions: v6buicks
Boostie
2,853
4,140
Sick, thanks for the feedback. After redoing my workspace in my garage I lost my welding surface and don't want anything permanent. This would be nice to fold up and not take up floor space when im not burning metal.
Reactions: LikeABauce302
LikeABauce302
5,930
16,526
South suburbs
Matt
Today I finalized how the alternator is going to be mounted. I used a mix of old alternator bracket parts to make something that works and I cut out a piece of aluminum plate to brace the alternator to the motor plate. I ordered some spacers and hardware from McMaster Carr for the support bracket.
