leaking water from cabin roof light assembly... wtf!?
Freebeer187
The Bolt Rounder
Schaumburg
So I hop in my car to go to work and notice drops of water by the shifter. I look up and water is dripping from the sunroof/interior roof light assembly. Has anyone ever seen this? Its got a good amount of water in it. Never happened before. The sunroof is closed.
Bru
Probably a water drain from the sunroof that's clogged.
DanJoy
You got a sunroof? I know on my car the drain tubes can get clogged and that can happen. The holes for the drain tubes should be in the corners of the sunroof opening when you open the glass
1FastWS6
Slow and only getting Slower...
My car was covered with leaves this morning
There are tubes that come out down by the doors, try and get a compressor and blow it out. Same thing happened in my red one, and that cleared it up.
99PONTIACGP
Chicago
Yep, it happens to me once in a while. I heard the sunroofs are notorious for leaking too :dunno:
Euro
GM or Nothing
Roselle
Mine did that once one day, never again. Strange! I just have to keep re-doing the god damn wiper cowl weatherstripping :madfawk:
The Broken Regal
BITE BITE, SIP SIP
Wheaton
x2 on the wiper cowl weatherstripping... a little leak from your overhead aint nothing when you've got a swimming pool in your passenger foot-well the morning after it rains
99PONTIACGP
Chicago
IS THAT WHERE IT LEAKS! My passenger side is always soaked. :dunno:
Euro
GM or Nothing
Roselle
That shit's annoying. I put some silicone on my stripping though and it's lasted a good 2 years and now starting to fuck up again.
Yeah, I fixed mine at school in spring of 08, and I'm pretty sure it needs to be adjusted/fixed again.
The initial findings were horrible, there was so much water on the passenger side of the car, that it was leaking out from the rubber stop that's right under the rear pass. side footwell. I had water in the front and back footwells.
Shampooing the carpet multiple times, the carpet still smells if you get close to it :tear:
Harbor Master
knock on wood... my car has never leaked.
G_T_P
x2 i have been getting this lately. I leave my sunroof open and i think a leaf gets clogged in there sometimes take a little while for it to come out i believe?
