Need a TV for Cub gamesPicked up the stools and assembled them yesterday. Heading to Menards soon for material to finish the wall and shelves.
I’d rather shoot trim nails through my hands.Need a TV for Cub games
Black pipe fittings always rust anyway. The pipe itself has a lacquer on it, fittings don’t. Go take a look at your gas lines, fittings will all be rusty and the pipe is mintWell there was a bottle of tile cleaner that leaked in the bag when I bought the hardware and I guess it got into the 2 bags of flanges causing some to rust. I cleaned them up with some scotch bright and they look kind of cool. I put together the pipes, flanged and caps, wiped them down with acatone and sprayed them with 2 coats of satin clear. I also sprayed the pipe straps black. Going to start mounting the hardware tomorrow.
Absolutely. I was hoping to get them cleared before rust started but the tile cleaner accelerated it.Black pipe fittings always rust anyway. The pipe itself has a lacquer on it, fittings don’t. Go take a look at your gas lines, fittings will all be rusty and the pipe is mint
patina**Absolutely. I was hoping to get them cleared before rust started but the tile cleaner accelerated it.
Yeah, shouldn’t be an issue but they’re not as robust as the others into the stud. They should be fine once I anchor the shelves to the pipes.
With the right anchors you should be fine, no?
It’s gone now.I dig it. Except for the uniform straight grout line on the right shelf side.
You may have everyone else fooled…but I know.
Need pic of mook sitting at bar with a sipz
