So on the wrecked Camaro I got the driver's side LCA removed with no issue, but I cannot get the bolt out on the passenger side LCA where it fastens to the frame. The back of the aftermarket subframes bolt up using the LCA bolt. I am not sure if the frame is tweaked binding the subframe against the bolt, but I have tried jacking the car on the back portion of the subframe to relieve some pressure and it does not help. There is about 3-4 inches of space to work with on the end of the bolt so there is no way to get a BFH (Big Fucking Hammer) in there to pound it through.
Last resort is drilling a hole in the frame to put a socket extension with a socket over the end of the bolt so I can pound it through with the BFH. Any other suggestions?
