Think I’ve got the fungus under control but now dealing with heat stress. With the amount of nitrogen and iron I’ve pumped through this front yard, it should be a lush deep green, but it is not. Put down a 7-0-20 granular the other day that’s supposed to help with stress from heat and disease due to the higher potassium level. Being on city water I hate watering the lawn if I don’t have to but its definitely come to that point considering we haven’t got much of any measurable rain in over a week. I was using Senninger Wobbler sprinkler heads but couldn’t get the corners since they throw water in a complete circle. Rigged up some rainbird 5000 rotors to sprinkler spikes and I think they’re my favorite sprinkler I’ve used so far. Adjustable arc from 40-360 degrees and you can run them from 1-8 gallons per minute in high or low angle throw.
Also tried my hand at stone edging while I was off for the baby. I figured I could just buy some edge stones and throw them in my existing rough spade edge, backfill them and call it good. I was wrong. Turned into a 2 hour project plus multiple trips to Home Depot. Trenched it out deep enough to put down an inch of paver base sand, tap a brick into place with a rubber mallet, check with the level, adjust the sand, tap repeat. Locked it in with some plastic pro flex edging and spikes, filled the dirt back in and put some seed down. Hope this helps with my mulch washing into the yard when we get torrential downpours.
