🔧 BUILD LAME Turbo V6 Camaro
2018-2019
1. A late introduction
4. Fuel pump trap door
2020
18. T5 Pro5.0 shifter
-TKX conversion
-TKX swap official write-up
2021
24. Custom center caps
26. CAI V2.0
35. N2MB WOT box
2022
47. Sizing a better turbo
49. Firewall brace
50. New ECM
2023
Now back to 2018!
The car is now equipped with:
-6765 ebay turbo
-Precision PW40 wastegate
-Air to air ebay intercooler
-AEM 50-1200 fuel pump
-Open 3” downpipe
-Custom 3” charge pipes
-Intense mail order tune
-Spec Stage 1 clutch kit
v6buicks
6,351
15,761
Franklin, IN
Jon
100th reply! Of course it's to myself... At least it's a positive update!
I finally figured out this stupid narrow band thing. After lots of thinking and no actual diag it didn't make sense that I my car was still calculating fuel trims, running pretty well according to the wide band, not having a CEL, and not having any response at all from one O2 sensor.
I started screwing around on the Torque forum and Aeroforce manuals where I was reminded about how GM name's their sensors weird (and flat out wrong IMO). I was viewing S1B1 and S1B2 which is bank one and post cat.... what I needed to be viewing was S1B1 and S1B3... as if my engine has three banks, but whatever. It's fixed! I can finally see what's going on and it feels great.
v6buicks
6,351
15,761
Franklin, IN
Jon
I've been enjoying the car a lot now that I know it's running pretty well. It turns out I need to turn my boost down a little though.:s00ls: I'm still embarrassed by all the smoke coming out from under the hood while sitting at lights though. Moving on...
I'm trying to get this PCV stuff sorted out so that I can justify replacing seals. I applied some compressed air to it and noticed that it doesn't really seal when closed, so here I am.
Anybody have any ideas of where to tap in for a catch can on an F-body? Id like to go into the valley if possible. Otherwise, I'll try welding some fittings on to the valve covers.
v6buicks
6,351
15,761
Franklin, IN
Jon
I didn't want this to open a big can of worms with this simple project, but it's heading that way already. Despite the "No fucks given" vibe I was initially going for, most of the efforts I have put into it have been fairly well planned and thought out. I don't just want a catch can to be in the way or look out of place. I still have very little money in this car, but "no fucks given" just isn't how I like to do things.
The AC is mostly deleted and never coming back, so the evaporator box is just in my way and looking ugly. I keep thinking that a firewall plate would be a really nice place to mount a catch can. The parts that suck are the labor involved in installing one and the fact that none of them seem to have provisions for keeping heater function. I may just run the valve cover breather for a while, and see if this fix alone helps my smoking problems. I can probably worry about the catch can later.
v6buicks
6,351
15,761
Franklin, IN
Jon
My mind changes every day....
I put the PCV plug in last night night and drove the car to work today. This did a lot more good than I expected! In fact, I might try to get away with no catch can. I no longer have obnoxious clouds coming from the breather or rear main seal, but my tune is off now. It sits at around 7:1 for a minute on start up before finally adjusting. I figured this would happen, but it's for the best in the end. I'll keep an eye on my breather and seals. Hopefully I don't have to do the rear main after all! Fingers crossed.
SaturdaysGS
4,985
2,003
Chicago (Southside)
PCV plug? Interesting...
v6buicks
6,351
15,761
Franklin, IN
Jon
I'm unsure on the fbody intake, but is there possibly another passage that needs plugged in addition to the pcv?
There are essentially just two holes. One is in the bottom of the plenum that goes down to the valley through the LIM. This is where the PCV resides. The other one is directly above the lower hole on top of the plenum, and that's only used to make replacing the PCV possible. It's covered with a plate and has a spring between the plate and the valve which keeps the assembly in place.
Since the the PCV is already inside the plenum, there is no vacuum leak that needs to be sealed off.
Mattstrike
Random Crazy Custom Car guy
Feb 13, 2014
542
1,139
When you put a breather on the valve cover, using a pcv plug, there will be an un-metered air source.
The side of the PCV that goes to the port between the MAF and throttle plate goes directly to the crank case. The PCV valve goes between the crank case and the vacuum side of the throttle. Even if you skip the catch can you still need a check valve on the breather.
v6buicks
6,351
15,761
Franklin, IN
Jon
Do you know of any valve cover mounted breathers that would work for this situation? All the breathers I can find for modern GM covers are the style I have with no fitting. In the long run I'd like to weld fittings to the valve covers and put the oil cap back on, but for now I'd like to keep it simple if possible.
v6buicks
6,351
15,761
Franklin, IN
Jon
The smoke is back, so the plug is coming out. I really don't know how to explain this. At least with my GN the smoke only comes out when I'm at WOT and maybe a few seconds after. This car smokes whenever it's hot, and it doesn't even smell like oil... I don't get it. It doesn't help that I can't really tell where it's coming from. It's just kind of burning off the passenger side manifold which made me thing oil from the breather. The crossover pipe smokes directly under the oil pan too.
Life in general is kind of kicking my ass right now, and the cars aren't helping. I might just park them for a while and enjoy my air conditioning.
Mattstrike
Feb 13, 2014
542
1,139
Ok. Think of it this way. Consider the crank case as an air tank. There is an inlet and an outlet. Both sides of the tank pull air after it's been metered by the MAS. So air circulating through doesn't effect AFR.
If you block the PCV valve (the outlet), air will stop flowing. But the inlet side, the passage is integrated into the throttle body casting and is the hole between the throttle plate and the MAS, is still open. When the crankcase starts getting pressurized because of turbo boost, all that oily mist gets blown into the throttle body.
If you put a breather on the valve cover, you're adding another inlet except the air is not coming from behind the MAS. You have un-metered air anytime air flows through the throttle body that is coming from the breather, through the crank case, through the port in the throttle body and into the TB after the MAS. Under boost, you will have a lot of flow out of the breather, but there is also decent amount of flow backwards into the throttle body still.
So your PCV options are (1) live with a little oil burning and use the type of setup I have on my truck and most likely what's on your GN. This requires a PCV valve to be functioning. (2) add a one-way valve to the breather, and put a catch can between the port on the throttle body and the crank case. Again, PCV valve still there. (3) completely separate the PCV from the metered air side of the intake by blocking both PCV valve and TB passage, put a catch can between the crank case and a breather to only vent excess pressure.
SaturdaysGS
4,985
2,003
Chicago (Southside)
I hate to somewhat derail this thread, but it’s related and reading all this info I seem to be confusing myself. My turbo GP has a PCV valve and a vacuum line running from that location to the MAP sensor, as well as teed into a line running to the blow valve. Is this correct? It has a breather but I’m assuming it should have a catch can instead?
v6buicks
6,351
15,761
Franklin, IN
Jon
Thanks for the explanation. I think I'm starting to get on the same page. Part of what was hanging me up was all this pre-throttle talk. Due to the location of the PCV, I was in a bit of denial that there was a passage in the intake connecting the valve to the throttle body. However, I can see it in diagrams, and I just realized that I never removed the throttle body when I pulled the intake off. I wouldn't have seen it for my self. I think tapping into that passage would be tricky since there aren't any hoses. It's all cast into the intake and throttle body.
I'll have to take a look at your truck thread and see what you did. I'll check to see what my GN is doing too, but it smokes bad enough to to shut down a track for a few minutes... That's what I'm trying to get away from.
Mattstrike
Feb 13, 2014
542
1,139
The cover plate above the PCV valve on the F-body intake is a manifold pressure reference. It sees vacuum at idle and pressure under boost. Adding a vac line there for the BOV or to a MAP sensor would be fine, though without seeing it I couldn't tell you why they didn't use the factory MAP sensor location.
I think the plastic (fwd) intakes are different, don't know if you can drill out and tap the cover for the PCV valve to do that, but it doesn't sound like it's necessarily related to the PCV system - it was done out of convenience. I don't know that the metal (fwd) intake looks like, but doesn't matter, the idea is the same.
As far as the reason for the catch can - the air inside the crank case is basically an oily mist. The original function of the PCV is to circulate air and help remove environmentally problematic vapors from the crankcase, as well as water vapor, and burn them and send what's left to the cat, controlling those emissions. The amount of oil mist that gets taken in and burnt off is minimal in a factory system, compared to what happens when you account the additional flow from blow-by under boost. Keeping oil out of the combustion chamber in a boosted application is more important: enter the catch can.
Again, depending on how your pcv is setup determines where the catch can needs to go.
Throwing a breather on a valve cover with nothing else done only prevents excess crankcase pressure and opens an un-metered air source (which can probably be tuned for). A breather + check valve prevents excess pressure, but doesn't allow un-metered air. Both methods are not as 'green' as a closed PCV system. Both allow the oil mist to enter the intake and or exhaust from the breather.
Putting a catch can between the breather and the check valve prevents oil mist from exiting the breather, keeping the engine bay and exhaust manifolds clean. It's the simplest way of modifying the existing PCV system for these 3800 turbo cars and still retain a reasonable yet partial emissions control over the crankcase - but still allows some oil to be drawn into the intake.
If you wanted a proper, closed PCV system on a turbo setup, it's much more involved, especially if you want to keep 100% of the oil out of the intake as well, you need two catch cans, a stock pcv valve that can handle the pressure you're running, completely re-routing both sides of the PCV through the catch cans, and block off the port to the throttle body, no breather valve. Then, relocate the MAS to the intake side of the turbo. A new port, between the MAS and turbo intake, goes to the first catch can, then directly to the crank case. The second catch can goes between the PCV valve and the crank case. Probably a lot more work than anybody really cares to do for the minor emissions difference between the breather setup.
The only reason to block the PCV valve is if you're essentially deleting the emissions control. Completely blocked off from the intake with a breather (with or without catch can) lets everything breathe in and out of the crankcase, "harmful vapors" included.
Mattstrike
Feb 13, 2014
542
1,139
After reading a little bit of what you're going through, I think the big thing you're fighting is a rear main seal oil leak. I had this problem on mine, with many new rear seals. It got so annoying I ended up turning a custom rear main seal press thing for my hydraulic press to make sure it went in perfectly straight, and bought the AC Delco rear main. Every other rear main (felpro, mahle, whatever) leaked bad enough to send clouds of smoke anytime I hit WOT. It's the worst after an oil change and the oil pan is full.
v6buicks
6,351
15,761
Franklin, IN
Jon
You may be right, I have been going a bit crazy over this. The trouble I'm having with all of this PCV/smoking/whatever issue is that the car never even smells like oil... In fact it smells like paint and the back of the oil pan isn't even wet. I'm running Rotella 10W-40. Does that smell different? I DID paint and wrap my crossover pipe which is what is smoking really bad right under the rear main. Coincidence? I doubt it. The paint should have cured and quit smoking many heat cycles ago. My brain hurts, and I've been parking this car on and off for my mental health's sake.
v6buicks
6,351
15,761
Franklin, IN
Jon
FWIW I don't mean this to come off as bitchy. I'm not giving up on this car. In fact it's the only one in the fleet that I haven't considered selling. I'm overall pretty proud of what I've made this turd into. I just need a break from working in this crazy humidity!
v6buicks
6,351
15,761
Franklin, IN
Jon
I got a bit bored at work today and found some pretty in-depth PCV information from Pennock's Fiero Forum as well as some older turbo GM sites. I may end up killing two birds with one stone.
My GN has an aftermarket part store PCV valve in it. I've learned that these don't actually close worth a crap under boost. The AC Delco parts were the only good ones because they were actually designed for The GN, Sy/Ty, Turbo Sunbird, ect. Unfortunately, they are no longer produced. However, smaller outfits will sell you a custom brass/billet PCV that's better than stock which is what I will probably go ahead and buy for that car.
With this in mind, I will probably have to get crafty with the Camaro because the stock PCV is pretty much the same part as the aftermarket GN valves. So far it's looking like I need to hack up the nice little PCV spring and retainer plate to externally route my vacuum to the throttle body. This would be the only way I can think of effectively incorporating a check valve. I just don't yet know how I will get it done while making it look nice. It's possible that the fancy GN valve would work though. I might have to do some test fits.
Mattstrike, I'm sure this is what you were saying all along. I just needed to read it a different way. Thanks for your help!
Mattstrike
Feb 13, 2014
542
1,139
I wasn't aware of the pcv valves not sealing well. I could see how in the GN a discontinued part puts you at the mercy of the aftermarket - but I thought the 3800 parts didn't have that issue. The only smoke I got out of my truck has been from oil leaks in the turbo seals. If it's really an issue, maybe the turbo cobalt pcv valve could be adapted?
v6buicks
6,351
15,761
Franklin, IN
Jon
Yeah, I can just blow through them with lung pressure. If I put actual pressure to it with my compressor it doesn't seal at all. I'll look into the Cobalt as well! That may be a closer match.
v6buicks
6,351
15,761
Franklin, IN
Jon
I did a little experimenting last night. The Camaro PCV is on the left and the cheapo aftermarket PCV is on the right. Look familiar?
How about now?
The GN part doesn't fit without cutting the big nipple off the bottom, but that's not a big deal. This proves that a stock GN part will at least fit, but I'm not conviced that the drop-in Grand National part from RJC is going to be as "drop-in" to the Camaro.
I'm thinking its going to need a strategically sized washer to keep the spring tension on it. The big kicker is that there isn't a lip for the o-ring. The GN just has a big grommet , so the o-ring is not needed. I don't think I'm going to be able to do much about that.
A choice that would probably work better without much creativity is a Delco GN valve. You can still buy them from restoration companies like Highway Stars, but once they are gone they are gone, so it's not very sustainable if I have a problem with it down the road. Besides, even GN guys have said that they have to run check valves in line with theirs.
GM has since changed their design completely. One side has a quick connect end, and the other has a hose fitting. I haven't found out how big the OD of the QC is, but I might get lucky. They are cheap enough, so I'm going to try getting one of these from the part store and taking some measurements.
I'm finally done pulling my hair out over my girlfriend's Volvo 240 instrument cluster, so the Camaro is next in line for my love. lol
