🔧 BUILD LAME Turbo V6 Camaro
2018-2019
1. A late introduction
4. Fuel pump trap door
2020
18. T5 Pro5.0 shifter
-TKX conversion
-TKX swap official write-up
2021
24. Custom center caps
26. CAI V2.0
35. N2MB WOT box
2022
47. Sizing a better turbo
49. Firewall brace
50. New ECM
2023
Now back to 2018!
The car is now equipped with:
-6765 ebay turbo
-Precision PW40 wastegate
-Air to air ebay intercooler
-AEM 50-1200 fuel pump
-Open 3” downpipe
-Custom 3” charge pipes
-Intense mail order tune
-Spec Stage 1 clutch kit
v6buicks
6,369
15,814
Franklin, IN
Jon
Man, it's always something like that that kicks a guy right in the nuts
Yeah, it sucks. I just need to stick with it though. I've never done a conversion like this AND I'm kinda pioneering the process for this engine and transmission combo. Now that the info is here, anybody can learn from it. It's just a little more expensive and time consuming when you're the guinea pig.
I have a lot of thinking and planning to do.
Reactions: Rdrnnr
v6buicks
6,369
15,814
Franklin, IN
Jon
ah fuck
at least thats a non threaded hole just for the dowel sleeve
I actually kinda wish it was the threaded one so that I could get a punch behind it and beat the shit out of it. I could also thread the bolt in backward to press it out. I don't know how I'm going to extract this one. Any ideas?
Reactions: Rdrnnr
v6buicks
6,369
15,814
Franklin, IN
Jon
I went at it for another hour or too. She's FUBAR.
As I lied there under the car and debated the whole meaning of life, I tried planning my K-member drop. Once again though, I settled on a plan to skirt around that. I ordered a right angle drill and some stubby bits. While there was no chance of getting the cordless drill and standard bit straight with the tunnel in the way, there's still a chance that something smaller will. ? I'm just gonna have to be careful not to mess this hole up any more than it is.
Reactions: Rdrnnr
Rdrnnr
wannabe racecar builder
Nov 15, 2020
1,361
2,386
Stock. It's tuned with DHP and HP Tuners by Brian Turner at Dyno Tune Motorsports in Columbus, OH. I will probably switch to a more desirable stock ECU or MS2 down the road if Tremec ever decides to start building and shipping TKXs again.
So, I still got a 7440 on the shelf ill hook ya up with cheap when your ready. I'll even toss a base file with your vin in it for ya ?
Reactions: v6buicks
v6buicks
6,369
15,814
Franklin, IN
Jon
That's enticing, but I'm not going to pull the trigger because I'm stubborn AF and really want to figure out how to do all the programming myself. lol I admit that I haven't made a strong effort to get my Tiny Tuner working though. Does it not work on Windows 10?
Rdrnnr
Nov 15, 2020
1,361
2,386
If you were into that Dropbox folder I believe there's a version in there if not quick Google search and some limewireish fun and your good. If you can't find what you need I pulled a copy of that whole dropbox to my old laptop so I've got all the bin files too. And if id go back whatever James sent me is in my email somewhere too. That's alot of pages ago lol
Pro Stock John
LS is the best engine
10,625
14,534
Chicago North Side
I'd go Holley Terminator over Megasquirt.
v6buicks
6,369
15,814
Franklin, IN
Jon
lol Yeah this thread is extremely tough to navigate. I'm glad I made a table of contents for the highlights. Anyway, I have the folder saved on my laptop at home. I'll screw with it later. Right now, the GN is taking a higher priority. Maybe if I blow through the intercooler swap (probably won't) I'll do some Camaro stuff.
I'm not against that. I've heard it's pretty superior, and I have a friend who can probably help me with it if I need. As a newbie, I'm just really attracted to the low cost and simplicity of Microsquirt. Needing to stick to batch fire with MS2 would kinda suck though.
  • Love
Reactions: Rdrnnr
32,646
16,117
Problem is is most aftermarket EFI does not have transmission control outputs. I remember looking into this a while ago and BS3 was looking at adding that functionality. I haven't found anything like that since but I haven't looked. I was looking at the functionality of the can bus interconnect for the megasquirt EMS Pro for the twin engine Olds....I could have her front and rear power train controllers communicate for traction control events.
Reactions: Rdrnnr
