🔧 BUILD LAME Turbo V6 Camaro
2018-2019
1. A late introduction
4. Fuel pump trap door
2020
18. T5 Pro5.0 shifter
-TKX conversion
-TKX swap official write-up
2021
24. Custom center caps
26. CAI V2.0
35. N2MB WOT box
2022
47. Sizing a better turbo
49. Firewall brace
50. New ECM
2023
Now back to 2018!
The car is now equipped with:
-6765 ebay turbo
-Precision PW40 wastegate
-Air to air ebay intercooler
-AEM 50-1200 fuel pump
-Open 3” downpipe
-Custom 3” charge pipes
-Intense mail order tune
-Spec Stage 1 clutch kit
Rdrnnr
wannabe racecar builder
Nov 15, 2020
1,361
2,386
Is there a reason your goin with solid line for your drain? Braided pushlok woulda been alot easier route. Also your not wrong about layin under these things screwin around especially if your tryin to drill the crank, I don't wanna see the bottom of my car again for a while
v6buicks
6,258
15,452
Franklin, IN
Jon
It's too long and floppy. I can't guarantee that the path is down hill all the time or that it won't be rubbing on something it shouldn't unless it's a hard line.
Rdrnnr
Nov 15, 2020
1,361
2,386
Dude idk the braided stuff I have wouldn't be the best for makin corners with and will basically stand straight up other than the natural curve. I totally get not wanting it to move tho.
Now that I'm thinkin about it tho I was kickin around puttin a power steering cooler in my drain line to help cool it but if it all needs to run downhill maybe that's not such a great idea
v6buicks
6,258
15,452
Franklin, IN
Jon
I just link a hard line is a lot sexier than hose anyway. lol
Yeah, if you don't have a scavenge pump to suck all that out, your cooler would just back up the flow and mess up your turbo. If you want to cool the oil, you're going to want an oil filter adapter where you can run the cooler off that. If cooking the oil inside your turbo is the concern then maybe you'll consider a turbo timer? I just don't shut my car off while it's in boost. I figure that's good enough. lol
  • Love
Reactions: Rdrnnr
Rdrnnr
Nov 15, 2020
1,361
2,386
I
Ive actually got a timer but I wouldn't count on me hooking it up ? I just set the fans to run for a couple minutes after she's shut off. I haven't had any issues so far but I can't imagine shovin oil that hot through the block is the best thing in the world. But hot oil is better than no oil or shovin it out the exhaust and toasting journal bearings and hardline will definitely be sexier.
Remembering I just spent the better part of last night screwin with tryin to make a hidden part of a header pretty I might just shut up now :ROFLMAO:
Reactions: v6buicks
v6buicks
6,258
15,452
Franklin, IN
Jon
Dude don't say that. I've had the same thought a few times as long as mines been sittin apart on the rack and then workin on it at the end of the day and as much as I bounce back and forth between things that's a real concern of mine
haha I'm sure it'll be fine. I think as long as I keep remembering to look at the notes and update them every once in a while I'll be okay. I just need to double check them before I fire the car up. I keep a long list in my phone.
Reactions: Rdrnnr
v6buicks
6,258
15,452
Franklin, IN
Jon
After hours either on my back or hunched over and pretzel legged I finished the crank. All seven bolts were torqued to 70 ft-lbs except for the last one. It went righty loosey.
I kinda just said "well shit", picked up my tools, and went inside. I don't think a thread insert is going to be possible here. In fact, I bet I would throw off the the balance. R.I.P? Weld the bolt to the flywheel and hope that the rest of the bolts will do their job?
Reactions: Rdrnnr
v6buicks
6,258
15,452
Franklin, IN
Jon
Thread insert would be fine that tiny bit of metal that close to the crankshaft Centerline would probably equate less than a gram out near the balance point where the counter weight is
I rethought that and agree. My next concern was whether it could even take a helicoil. If it was the hole closest to the balance drilling, I'd be screwed, because I'd be turning two holes into one.
Just checked. It's NOT that hole.
Helicoil time
Reactions: Rdrnnr
v6buicks
6,258
15,452
Franklin, IN
Jon
I finally finished something. It's not as good as I wanted it to be, but it's done. I'll fix it if there's a problem later.
So the pipe itself turned out pretty good. What I forgot to account for was the length of my turbo's drain fitting.
Here's a better view of the lack of slope. I think it will be fine. I'm crossing it off the list.
Reactions: GTPpower
v6buicks
6,258
15,452
Franklin, IN
Jon
A 45 is how I have mine right now. I wonder if it's because its pointing more forward and then goes back around. I'm still leaning more towards a blockage tho it's really mistin out of there lol
Yeah, mine will too because I'm an idiot and never actually fixed the root cause. I need to replace the oring on my flange because it wasn't the right size to begin with. THAT is something I actually plan to fix before I start the car again though. I have a big oring stash at work that should have what I need.
Reactions: Rdrnnr
Rdrnnr
Nov 15, 2020
1,361
2,386
I literally pulled mine outside to pull a customer's truck in for a diff drop, let it sit in the snow last night and today, ended up runnin circles all day and it's probably not movin til tomorrow now. I'm bout certain there's a plug in the bottom I forgot to take out and my luck I blew the seals out of a thousand dollar turbo
v6buicks
6,258
15,452
Franklin, IN
Jon
The helicoil was about 3 threads too short. While I'm not happy about that, it's still holding the full 70 ft-lbs. (y) Time to move on. While that's a massive weight off my shoulders, I still have a few big hurdles in my way.
By the way. Jegs teased me. The transmission did not ship on Monday. I'm back to the original date of 4/26. I still have very little hope of that actually happening though. I'll believe it when I see it.
Reactions: Rdrnnr and GTPpower
v6buicks
6,258
15,452
Franklin, IN
Jon
I went to check my the run out of the bell bore thinking it was either going to be great or only need a minor adjustment. Nope. It's out so far that my gauge can't measure it (0.05"+) My bell does not want to go on without a hammer either. I tried popping the pins out, rechecking the high spot, filing the rough edges, and putting it all back together. No change. I'm at a complete loss of what to check or try.
v6buicks
6,258
15,452
Franklin, IN
Jon
New situation:
This guy's stuck. Just this one. Luckily I was able to remove the other one fairly easily to do some further investigation.
I did some more measuring, and discovered that these pins are tapered. Since I did not notice this before, I can bet that I pounded the big end into the block. This is probably causing everything to sit crooked and not let the bell sit correctly.
Sooooo this puts me back about 20 steps on my list. There is no chance of me pulling this pin out with the engine still in the car. In fact, it may not come out at all without seriously mangling the block.
