🔧 BUILD LAME Turbo V6 Camaro
2018-2019
1. A late introduction
4. Fuel pump trap door
2020
18. T5 Pro5.0 shifter
-TKX conversion
-TKX swap official write-up
2021
24. Custom center caps
26. CAI V2.0
35. N2MB WOT box
2022
47. Sizing a better turbo
49. Firewall brace
50. New ECM
2023
Now back to 2018!
The car is now equipped with:
-6765 ebay turbo
-Precision PW40 wastegate
-Air to air ebay intercooler
-AEM 50-1200 fuel pump
-Open 3” downpipe
-Custom 3” charge pipes
-Intense mail order tune
-Spec Stage 1 clutch kit
SaturdaysGS
4,985
2,003
Chicago (Southside)
i gotta dig my vintage win xp laptop out to get the other files but i emailed Wiley coyote the TT and DB
i gotta dig it out anyways to take the TR back from full retard when we spun the tires at 105mph at 26 psi n shredded the ISS
Gmail won’t let me send TT says the file type is associated with virus’ lol
Idk where my bins went, lame.
  • Sad
Reactions: v6buicks
v6buicks
6,352
15,761
Franklin, IN
Jon
Reactions: Rdrnnr
Rdrnnr
wannabe racecar builder
Nov 15, 2020
1,361
2,386
It looks like I have it, but there won't be much I can play with until I either get my hardware or a random .bin file.
R YingYangY87thang go here http://theblattners.com:82/projects/tinytuner/Default.html, follow those directions, and download winZip. It felt sketchy, but I eventually got this nice square with buttons and a band-aid icon. lmao
Yessss. Look at us gettin into big boy things with little catfishes. Finding this forum was the best thing I could've ever done for my car
v6buicks
6,352
15,761
Franklin, IN
Jon
And the worst thing for my wallet. I probably would have taken this thing up to ZZP for a dyno tune, and made them deal with it until it blew up. Then I'd go do something else. Now it's gonna be 100% my fault when it blows up instead. Lmao
Reactions: Rdrnnr
Rdrnnr
Nov 15, 2020
1,361
2,386
Ya know. I don't hate the base tune they put in it other than they didn't do any ve, the o2 sensor thing and it bein 9.5 rich and commanded 12.0 but I get playin it safe. And had my car been runnin right when I had tim do the remote tuning id have never gotten this far. I do kinda wanna send him an email and ask him a couple questions now that I know a few things besides hey I bolted this ebay piece of shit on can you make my car run but with the general feel of things before idk how well he'd take to bein questioned [emoji23]
v6buicks
6,352
15,761
Franklin, IN
Jon
Lol I wasn't bashing ZZP. I would just quickly get tired of spending all that money to have them tune it every time I changed something.
Rdrnnr
Nov 15, 2020
1,361
2,386
250 for the start and 50 a throw thereafter. It wasn't really about the money to me its more of a I have respect for them but id rather do it myself than to wait for 3 days between flashes while being told my cars fucked up. He wasn't wrong but damn man little help would go a long ass way when it comes to customer relations and I get the feeling they don't really care for our platform much unless parts interchange with the w bodys
Reactions: v6buicks
