I think I finally have a plan/compromise set for the winter.
I'm going to prolong the radiator and core support. As much as I want that done, there's nothing currently wrong with it. The cap stopped leaking, I don't have overheating issues, I don't ever expect to have any, and I can do this at any time with the engine still in place. Skip.
I'm also going to forget about the rear end for a while. My ratio is less than ideal and it is certainly a weak point. However, it's still kicking. I also don't think it will be a problem on the dyno. Skip.
I DO want to drop the K-member and install all the parts I've had sitting around. I can't live with the smoking issues and having all these parts hanging out is starting to annoy my wife. I'll rebush the control arms and buy coilovers in hopes of controlling this thing a little better. Sway bars and adjustable control arms will be skipped. While I have everything out, I'll remedy the rusty portions behind the core support and paint the engine bay. I'll also go through the harness, solder in the EV1 injector clips, delete the EGR wires, incorporate the MAF scaler so that it's not so ugly, finish the WOT box wiring, and possibly elongate ICM and AC wires.
That's a lot of work for a winter in a two car garage, but I believe it's doable. Now that I have a plan, I'm very motivated. In fact, I got back to a project I've been neglecting for a while. Notice it is not on the list for completion this winter either.
All the rough in's for fiberglass are done! I just need to support this new wall a little more because it's floppy as it stands.
