L36 Fuel pressure regulator for turbo
bs009
Michi-land
Can I run the stock FPR from the Camaro with positive pressure in the intake manifold?
reason I ask is because I'm looking at the injector flow rate tables for the L36 car and my L67 Regal and noticed that the Regal's flow rate changes with vacuum, where the L36 is pretty consistent.
stock for Regal:
Stock for Camaro:
I adjusted the Camaro tables for my 80lb injectors, but I'm wondering if I need to change this one to adjust for vacuum or boost pressure.
Maybe I could just unplug the vacuum line from the FPR to keep the pressure consistent?
I've also heard the diaphragms on these can go bad or something with higher boost levels.
jdredd
Switch to a L67 FPR so it has 1:1 pressure bump from the boost?
If you have a big ass fuel pump setup, you would be wise to switch to a bigger/better
aftermarket style regulator. To much flow from big pump will blow through it.
Few had this issue with the e85 450 pumps... switched to a Aeromotive or Magnafuel
regulator cleared it up.
bs009
Michi-land
That makes sense then. I've currently got a walbro 255lph pump in the car, but the more I read the more it sounds like I should've gone bigger there. So that'll probably happen in the next year or so or if the Walbro fails.
Sounds like I'll need an aftermarket regulator then. I'll have to look around and see what's out there.
thanks
SleeperLS
Desert Racer
Sandia Mountain
I had an Aeromotive fpr and it worked perfect the entire time I had my car. Would recommend.
bs009
Michi-land
So I'm looking at finding a way to put this together now, and it looks like my only real option here is to modify the factory fuel rail since I'm using the injector holes in the intake instead of where the L67 cars have theirs.
I will probably find a way to remove and weld up the hole for the regulator and maybe put an aftermarket regulator on the return side of the rail.
for reference, here's what the f-body rail looks like:
Before I buy an extra rail and spend the arm and leg on the regulator and its special fittings, are there any better options?
