Known Problems with Fixes
El Presidente
The other thread is a good start for targetting current issues that I'll need to hammer out so this thread will work as a Problem - Solution thread. I will update it each time I find, fix, or add something so check back often.
PLEASE DO NOT POST IN THIS THREAD
Problem:
Quick Reply and Advanced Reply dont show smilies or text editing stuff.
Solution:
Go to user cp > options > turn on enhanced or standar editing (at the bottom of the options basically). When everyone was ported over, you did not receive that setting. New users automatically have that set to start with.
Problem:
Go into a forum, go back out to main page and it still shows threads as new.
Solution:
Temporary fix...example: you go into OT b/c theres new threads. there are 2 new ones, you click thru...if you're like me ull usually just cilck back out to the main forum. dont! the quick fix for now is to do this...read the threads, then click back into the forum ure currently in THEN click back out to the main forum. that should eliminate the new thread icon :x: I'm looking into the real solution
Solution 2:
Just click on quick links, "todays new posts", go thru those then just go back to quick links and click mark all forums read
