Killer Chiller
FordNut
Talked with Joe Kincaid today about the KC. Gonna work with him to put together a kit for Marauders...
Zack
4 Doors 4 Life
NW Indiana
There are 2 guys on MM.net that have KC's on their car.
Dont ask me who, I dont remember.
DTUB
Active member
You could probably benifit from one of these Brian, i'm going E-85 so I hope I won't need one.
ProRauder
This. You'd have to put the fuel in much further from the head to get the full cooling effect of E85.
Sent from my DROIDX using Tapatalk
FordNut
Sent pics to Joe to try and work out fittings, adapters, hose routing...
Bob_Kurgan
Flyin_Hawaiin
in my experience, the KC isnt up to the hype.. dont get me wrong, it helps a BIT, but not as much as people hope... also, e85 fuel seems to make the motor run cooler, so you do see a slight benefit to the IAT's... again, just from my experience
Zack
4 Doors 4 Life
NW Indiana
All I am after is to be able to drive the car as it was intended to be in the hot summer months.
Translation: If I can keep my IAT's below 130 Ill be a happy camper.
musclemerc
This is why I think a KC type system needs to be adapted to the CAI side and not to the IC. I figured out how to keep condensation out of the CAI track and even came up with a drip design using a one way check valve. I still have alot of work to do on it though
I guess I'm gonna be the first to invest in making it work
Zack
4 Doors 4 Life
NW Indiana
I wouldnt waste your time or money.
A: It would only work on the CAI side of a NA Marauder. Marginal gains if any would be noticed
B: If you are not cooling down the IC fluid on a SC car, why bother at all?
Lowering the 'ambient' air temp on a SC car will only go so far. The entire point of the KC is to eliminate heat soak, which would most definitely not be accomplished with the methid you are proposing.
Sorry for disagreeing, just my .02
Bodyman
Warrenton,MO
Indeed...find me the time!
Youre just lucky you dont have kids added in the mix LOL Dont get me wrong I love them to death but a 2 day bodyreapair ended up being 4 days cause all the interuptions.:D
musclemerc
This is how great ideas are born, diffrent opinions. ;)
Not all Whipple/Eaton Swaps have to run a PS CAI. The guy that started this thread is and has always run a DS CAI without any issues.
I will continue my research and come up with a solution for this one day. Sometimes the answer to a problem is starring you right in the face :)
Zack
4 Doors 4 Life
NW Indiana
Im not gonna stop you from trying, but dont come crying when your pockets are empty with no good results!
Zack
4 Doors 4 Life
NW Indiana
Think of it this way:
If you had 40 degree air entering the intake tube, passing through a...lets say 150 degree intake tract, then to a 180 degree blower.
Blower compresses that air and heats it up, then it passes through the most ideal IC temp of ambient, lets say 90 degrees.
....y'all can do that math because I already know it aint the temp you want to see.
4DoorBlackTop
Why even do any of this at all? Last week I never overheated during city driving. I had on my A/C too. Just keep the radiator clean. That's all you guys have to do!
100 degree temperature + 550 horsepower Marauder / clean radiator = working car
Zack
4 Doors 4 Life
NW Indiana
Dominick, stay the fuck out of this thread.
You obviously dont know what the hell we are talking about.
JStevens
Active member
I'll be back after I wash my radiator.
It would be cool if we could feed ice cold water/fluid through the IC.
Zack
4 Doors 4 Life
NW Indiana
I emailed Joe Kincaid this morning, offering to use my car as a test mule.
...gonna need the KC after I install the Cobra engine and pulley the Eaton to 16psi.
Bodyman
Warrenton,MO
Now I know, I was wondering why my IAT's were getting so high these past few weeks;). I gotta get that radiator cleaned. That should drop my IAT's a bunch and not have the comp pulling a ton of timing out:headbang:
FordNut
I emailed Kincaid a bunch of pictures, never heard back. I haven't had a chance to call him again.
