key fob programming
UWISHU1
Hanover Park
Hey guys I bought a key fob remote off of Ebay for my 95 GP but don't know how to program it to the car, any help??
Thanks
BillyBru
FoodHead
look in the owners manual. my fob broke a few months ago. I need a new one...how much did you get yours for?
wombat
Wood Dale, IL
You can get them for brand new from gmpartsdirect.com for 30 bucks
Harbor Master
clubgp has how to program em
UWISHU1
UWISHU1
Hanover Park
I did as stated in the owners manual "hold lock and un lock" for 7 seconds til the horn chirps and nothing.
1998gpgt
Boulder, CO
From programyourremote.com
Note: Existing keyless remotes will be erased with this procedure.
Existing working remotes will have to reprogrammed also.
1. Locate the programming connector wire located in the RH trunk area.
You may have to pull back right side trunk trim on trunk wall to locate
the single black/white wire.
2. The programming connector wire should have one termial in the plastic
connector on end of black/white wire. Ground the terminal in the connector
to a nearby bolt or trunk latch.
Leave connector wire connected to ground through out procedure.
3. System will now lock and unlock doors automatically to indicate
programming mode has been activated.
4. Press any button on keyless remote. System will respond by locking
and unlocking doors one time to indicate successful programming.
5. Repeat step 4 for to program any additonal keyless remotes including
and existing keyless remotes. Do not remove ground wire between
programming of keyless remotes.
6. Disconnect programming connector wire from ground to exit programming
mode.
7. Test keyless remote(s).
