It just doesn't make sense why Honda put so much performance (sans oil pump) into an engine found in regular and boring family cars, but it is awesome.
Welp car stranded me. Hoping it's something easy like the fuel pump relay. Pump isn't kicking on.
That's what AAA is for lol.
Needed to sleep on it before I fucked up more shit. Wasn't my day lol. Couldn't find any decent gauge wire to cannibalize on the side of the road. And when I tried to jump the relay it was the wrong one cause I couldn't see jackshit under the dash. Which thankfully only popped one fuse. I had 4 free tows and needed to save my sanity.piece of wire to test it.....
I should've beefed up the relay. I totally forgot which pump I dropped in. Some of the upgraded dw pumps are fine on the stock relays, but the walbro I dropped in is too much and tends to kill the relay eventually.That's Mazda's fault![]()
Volvo fan relay is my vote. Look it up.I should've beefed up the relay. I totally forgot which pump I dropped in. Some of the upgraded dw pumps are fine on the stock relays, but the walbro I dropped in is too much and tends to kill the relay eventually.
Got a new stock relay on the way and then a second unit to run in tandem which should prevent this issue from happening again.
It usually takes a while for my level of pump to kill the relay, but I haven't been driving it other than once down the street and back.Yeah she got a bit of heat. Watch the contacts on that one too you may end up wanting to keep a relay and/or bypass in the trunk till you can step it up a hair.
Cause it made life easier, until it didn'tWhy would you use an add a fuse for your ECU?
The two that caught my eye were the new re71rs and the rt660s. The bfg rivals seems to be real popular too.The 200tw tires should really change how you feel about it a lot. What tire are you planning on going with?
