🔧 BUILD Junk fox 2 - Goals of an 8-second drag week street car turbo build from Dumpsterpat
Dumpsterpat
Oct 26, 2020
48
248
Ohio
Pat
Decided not to do drag week... Added nitrous to the car. I have a VS s485 & an 88/103 I picked up used I'm gonna try. I was very busy at work & home at the end of the season so I didn't get out much. Gonna finish the t6 hot side this weekend & try to head south for some testing if I can find a track to go to. Prolly just end up driving around & melting these worn out drag radials.
Dumpsterpat
Oct 26, 2020
48
248
Ohio
Pat
Are you still kicking around Drag Week or similar events?
Possibly, I register every year then the time comes & I skip it. Summers are busy for me & by the time September comes I'm pretty worn out. I usually just end up at the local track with a few friends. There's a no prep true street class my car fits in I may try next year. Might just continue burning up parts at test & tune like an asshole.
Dumpsterpat
Oct 26, 2020
48
248
Ohio
Pat
Ended up putting the 88/103 on. Why not. Here's some junk mild steel mig welded hot side & exhaust pics. Next im gonna attempt to tap the back side of the pump on my th400 and run it out of the case to a solenoid for an internal dump. Ill be doing external also. Ive been interested in these for a year or so & figured i should try & make one.
Dumpsterpat
Oct 26, 2020
48
248
Ohio
Pat
Did a few things over the past couple of months... Added:
Coan internal dump valve body.
Trans line, converter & coolant pressure sensors.
Converter pressure regulator & temp sensor. (All lowdoller motorsports)
Put some 275 pro's on.
Made a new gas pedal, I was having trouble keeping it at 100%.
Track rental next weekend.
Dumpsterpat
Oct 26, 2020
48
248
Ohio
Pat
Congrats! I'm guessing you met Jay and Brian with the Nova from MI. Jay is a friend and has helped me on my car a few times.
If it's the Jay from Jay wire solutions I did meet him. Talked to him for a little while by the porto john's at dragway 42. Really nice guy. I think they won the 8.50 class.
Reactions: Pro Stock John
