Jokerz new before and after
Jokerzl
Forum Sponsor
Ashkum
Jokerz Ported Blower Tested!
Here's my data from today. Peak gains are solid but some of the under the curve from 5,000 to 6,800 RPM gains of 30-40 hp and tq are super impressive. I included both corrected and uncorrected because the weather today and IAT2's are pretty much identical to what they were when I did the baseline and I feel that the uncorrected numbers might be closer to actual gains. The car feels great and was blowing the tires off at 70-80 mph in 3rd gear with no problem which its never been able to do that before.
Timing was locked in at 21 degrees for all runs before and after.
BEFORE RUN: IAT2 started at 97 and peaked at 118 degrees
AFTER RUN: IAT2 started 102 degrees, peaked at 120 degrees.
Roughly 55 degrees in the shop both days before/after
Boost was up about 1-1.5 PSI throughout the curve.
Corrected Dyno: Peak before: 637/620 Peak After: 660/630 Gain: +23RWHP/ +10Tq
Tagged Gain- 5,900RPM: Before: 617/550 After: 652/583 Gain: +35RWHP/+33TQ
Uncorrected Dyno: Peak Before: 651.5/635 Peak After: 679.5/648 Gains: 28RWHP/13RWTQ
Tagged 6,500 Gain: Before: 637.5/515 After: 673.5/544 Gains: 36RWHP/29 RWHP
