Jokerz CTS V build
Jokerzl
Forum Sponsor
Ashkum
Getting closer to being done
Mods so far
Forged 380ish built bottom end
Tim kings old heads with PAC springs
Custom grind cam
Stainless works headers and xpipe stock mufflers
10.2ish compression
E85 conversion with dms fuel system
ID 1050x injectors
2.45 griptech 9.1 ati lower stock idlers
Lpe relocation bracket
Joker chaos R port on a 1.9 or 2.3 tvs
Nick Williams Boosted 102 black throttle body
Maybe a ported ls3 silver 90 mm if issues arise
Ice tank in trunk with upgraded emp pump
Mjd heat exchanger
Vengeance coil wires
Zl1 milled lid with welded intercooler brick
Full weight I WILL NOT REMOVE INTERIOR
Nitto 305 Tires on stock rims
Need some light weight rims and tires for some fun nights in el mejico
Fired it up for the first time today
