Joker Port - cobra m112
Jokerzl
Forum Sponsor
Ashkum
2.8 upper only kn fipk intake off road h pipe flowmaster cat back and your port on 93 with 18 degrees of timing and it pegged maf and ran out of injectors
Stock plenum throttle body ported walbro 255
Stock maf and injectors
Comparable
Posi made 2 hp and 4 ft lbs
With a 2.76
60# injectors
Boost a pump
Dragon Tb plenum
So he was making .5 more lbs of boost which a # of boost equates to 12-15 hp and 5-10 ft lbs.
He made 515 hp 508 ft lbs
My guy ran out of maf and injector at 5700 and he was still pulling
https://www.facebook.com/Jokerzperformance/posts/373910299480620
boost21
Edit: didnt realize this was stock injectors
Nice numbers for a ported blower and 93
Jokerzl
Forum Sponsor
Ashkum
I just had a customer make 500 on 91 octane and 18 degrees with a 2.93 pulley
