I was invited but didnt make it. My guy said it was a blue Whippled Coyote, and it was semi local. So I thought possibly could have been you.No he has a VMP
What happened? good race?
It should. No emissions have been fucked with in tune.Did you think itd pass?
I thought you had long tubes.It should. No emissions have been fucked with in tune.
Do you think you know why it didn’t? Lol
I do have longtubes. I also don’t have cats. I’m thinking you’re not up to speed with todays tuning…I thought you had long tubes.
Nevermind then.
How do I check? I’m using an SCT handheldYou didn't check this before you went?
Did you just upload a new tune file or have the battery unhooked? Because if you did, you would have to complete drive loops to get the system monitors to report ready. That is IF your tune doesn't have any changes for those emissions items.
All the big name tuners will NOT fuck with anything that has to do with emissions these days ever since the crackdown. I’m running spacers on the rear O2’s to keep the computer thinking everything is just fine.
And yea, I forgot I changed E85 tunes a couple weeks back because the last time I took the car out a month ago, I realized I loaded the wrong one. Didn’t think about that until after I got the REJECT…lol
No, I really think you’re throwing darts with a fucking blindfold on. LolI think you are assuming alot carry on.
If the rear O2’s were turned off, the test would have come back and said “not supported”. I will confirm with Rob that all the emissions are left alone, but I’m pretty sure I’ve asked him before and he said he never fucks with that as it is against the law. The tune revision I’m using is from last fall which is well after the EPA came down hard on the tuners.I can't remember if SCT has a way to check monitor readiness. I'd bet it does tho. Cobb and others do.
I've always used a cheap Bluetooth ODBII dongle and the Torque app. Works great.
If your catless, your rear o2 are probably turned off. So the cats won't ever show ready. If you have extensions you can ask your tuner to turn the rear o2 on. That might work. It also might not. O2 extenders are so hit and miss.
You think this is struggling? You honestly think the car won’t pass once I drive it a couple more cycles and the monitors switch to “ready”?There are a few dickheads on this form that make me giggle when they are struggling.
You are one of them.
