Is this what I need to upgrade the fuel pump...
Ron Vogel
Bolingbrook
Yes, maybe...
The problem you are going to run into is you may have to cut the metal rods at the ends, and transfer the top part that sits in the top of the tank from the Bonnie over to it. There are a few different variations from year to year alone on the GP's; I imagine the Bonnie tank would be a little different.
you shouldnt have an issue pulling your bucket apart and dropping the pump in it.....i think there's only two buckets (venturi/non venturi) but there's alot of different uppers/rod/spring lengths for the different GM chassis' and tanks.
